Question about Ricoh Aficio AP410N Laser Printer
Sp 3510dn error code sc545
4 Suggested Answers
  • 95 Answers
SOURCE: Error Code of SC545
That code will not reset by powering off and on. It needs to be reset in the service mode.
Posted on Jun 22, 2009
  • 29 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Posted on Aug 18, 2009
SOURCE: Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Posted on Feb 08, 2010
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
Fix problems for error code sc 542 for ricoh 3510dn printer
1. Switch machine off.
2. Hold up and down arrows in while switching the machine on.
3. Select Service menu and OK.
4. Scroll to 5.Mode and OK.
5. Scroll to 810 SC/Jam reset and press OK.
6. Execute
7. Switch machine off and on again.
If code does not reset you would need to replace the Fusing Unit and follow the above steps again.
Jun 01, 2016 | Ricoh Aficio SP 3510DN
Error code sc545
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Aug 28, 2014 | Office Equipment & Supplies
How do I reset the printer error code sc545 on my savin printer
To reset the machine after SC545, enter
simply in the SP mode.
( C 1 0 7 stop )
Jun 22, 2011 | Savin 2575 Black and White Copier
REX ROTARY DSM618 D SC545 ERROR CODE
you have to go into the sp modes to clear this code .pres the yellow c then 107 and hold down the orange c , do this all in sequence , it wil go in the sp modes and show copy sp .enter there and switch the power off wait 5 seconds switch back on
Jul 18, 2008 | Gestetner DSm515pfd Digital Copier -...
Ricoh Aficio AP410N Laser Printer Logo
165 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
