Plese image this problem fix this code C-2105 in konica minolta bizhup 600
Fix this code C-2105 in konica minolta bizhup 600
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 18 Answers
Over my head
Posted on May 08, 2014
Fix this code C-2104 in konica minolta bizhup 600
You should check the Transfer and Sep. Assy. (It is directly below the drum) Its a Assy. that can be removed with two screws when you open the center of the machine.The motor that sends the cleaning device across those wires in that Assy. (the motor is on the Assy.) is stuck or bad. You can also prevent it from functioning by using the soft switches and turn that off, especially if you don't like hat high pitch squeal when you turn on your machine.
May 08, 2014 | Konica Minolta Developer 02xk Dv710 for...
Opeate fix this code C-2105 in konica minolta bizhup 600
Transfer/separation cleaning motor home sensor error. Most commonly caused by toner building up in sensor. Open front doors, lower center handle, and pull out transport unit. Located in the middle of the units paper path (to the right of the fuser) is the T/S unit. Located the two screws holding the unit in and loosen them, ones at the front the other is at the back. Pick the T/S unit straight up and out of the machine and clean out any toner and paper dust located in underneath. Reinstall unit and reboot machine.
How can state fix this code c-2105 in konica minolta bizhup 600
Open the middle of the machine in the center of that you will see a unit that has three very thin wires be careful they are very easy to break. They are covered by a plastic mesh these wires are what pulls the image off the drum and on to the paper. There is a cleaning device for these wires the code is telling you it did not complete the job. or it mite be stuck. it should be at one end it mite be in the middle. There is away to shut the cleaner off so it does not work at all. A lot of times it is not required.
Fault code c2401 on 750 bizhup
Check Erase Lamp, Update firmware if both of earlier didnt resolve the issue change printer control board it defenatly resolve the issue.
Jul 19, 2013 | Konica Minolta Developer 02xk Dv710 for...
How can fix this code C-2105 in konica minolta bizhup 600
C - 2105 Transfer/separation corona cleaning motor home sensor error code.
Remove the transfer/separator corona located in ADU assy,use the vacuum cleaner and clean the corona support and the 2 sensors(located under corona assy rear and front area).After cleaning urn ON the copier and is working.
Mar 16, 2013 | Konica Minolta Developer 02xk Dv710 for...
Check the Transfer/SEP assy. it is directly below the drum when you open the front section of the machine it will be a assy. with three very thin wires covered by a plastic guard there is cleaning device that cleans those wires when you turn on the machine. Check the drive for the cleaning motor, assy. can be removed two screws one in the front one in the back on the section you open. Motor is under the front part of the assy. Can be completely turned off via service mode soft switches.
Jul 21, 2012 | Konica Minolta Developer 02xk Dv710 for...
Error code 4701 for Konica Minolta bizhub pro C6500
- 4701 error
Communication fifo problem error 4702/4701 of 5500;6500;6501 konica minolta mfp printers
1) reseat all connectors in Ipb
2)image memery controle board
Inspite doing all these if the problem persists please reload the firm ware/flash firm ware.
Last one is to replace image memory board only .no need to replace prcb; overall status board; nvram
Jan 09, 2012 | Office Equipment & Supplies
Konica minolta bizhup 6501 error c-2452
Something with your developer causing not enough toner. Maybe an auger issue in the developer or in the toner feed itself?
May 19, 2009 | Konica Minolta bizhub C250 All-In-One...
jasbo
jasbo
