I have a laurastar steam iron and the steamer knob is missing where can I buy one please
SOURCE: steam from rowenta preassure iron and steamer
Hi, It is likely you have too much residual water in the iron or have mineral deposits from the tap water you have been using. Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
SOURCE: I have Laurastar steampump model 01-0165. How
Vinegar and water mix (about 1 to 4 ratio) and run through. Use distilled water only thereafter--rinse through several times to clear out vinegar.
SOURCE: my new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
SOURCE: IRON WILL NOT HEAT UP, LIGHT DOES NOT COME ON
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
SOURCE: Rowenta DA75 - Won't Steam
Using tips from previous commenter, Jason Collins, I thought to check for any blockage in the water flow.
Anyway, if you take out the water "tank" there is a black piece and a white/clear piece that are removable, I removed the white/clear piece and now it works fine! Hope it works for ya'll too.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
