Question about Frigidaire ATF6000ES Front Load Washer
Excissive spin noise
My Gallery front load washer (Model FWT647GHS0) is making what I consider to be excessive spin noise during the last spin cycle. When the tub is spun by hand, there is a rough friction feel rather than a smooth rotation. Any Ideas as ti what the problem is. Earl Dolven, epdolven@yahoo.vom
  • epdolven Jun 23, 2009
    It looks like a bearing problem. The supports are OK. Is it worth pursuing a repair? The machine is 7 - 8 years old. Earl Dolven
  • epdolven Jun 30, 2009
    Thanks for your help.
    President:
  • 392 Answers
If you remove the back panel you will see the shock that hold the tub up sometimes these will break or become weak and not hold the tub up stiffly and not absorb the movement if none are broken then you have a rear bearing issue! The jet engine sound is not normal these unit have a bearing in the back that are pressed into the rear drum when they sound like this the bearing is bad the only way to fix this is to change the rear drum n. So if the shocks test ok i would suspect the bearing has gone out!Ok if you need the shocks there is two plastic shafts that hold them on you will see them they just push out the part is the shocks take the model number to your local appliances parts house they can order them for you.
Posted on Jun 22, 2009
  • M.Jeevan Chaitanya
    M.Jeevan Chaitanya Jun 23, 2009
    Repairing depends upon you , My suggestion is better go for a new one , even if you repair it also ur machine will give about 2-3 years of service .Your Machine has given a very good service as u told that it is 7-8 years old.
    Thank you for contacting Fixya. Please Rate my Solution, which pays me for the service I provided.
  • 294 Answers
Have u ever thought if the problem has to do ne thing with the placement/mounting of the machine?? as jeevan.m has given the possible machanical reason apart from dat please note that..placing machine @ rite location to works. It is a good machine, made with good materials unlike the sub standard things used in new machines. Is the floor still solid, not getting weak or spongy? Do the feet have rubber left on them or are they just metal? Are the front feet screwed in a manner that lifts the front of the washer, if so, turn them down as far as they go, then lift the back of the machine by tilting it forward and let the self leveling back legs level the machine. you have checked the feet.....the rear ones are self leveling. Standing in front of the machine, tilt the machine toward you about three inches and let it drop back down on the rear feet. This will level the rear. Might also want to place some little rubber pieces under each of the feet to help from sliding and going more unbalance issues.. so as to minimise the sound. pl read. http://www.ehow.com/how_4704085_repair-washing-machine.htm
Thank you for contacting Fixya. Please Rate my Solution(help ful) which will pay me for the service I provided.
Posted on Jun 30, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Whirlpool Cabrio makes excessive noise during spin cycle
Your model has a bearing under the tub which is probably going bad and needs to be replaced. cabrio washer bearing replacement YouTube
Oct 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The washing machine makes a lot thumping noise during the drying cycle. Sounds like it is bout to take off. A lot of rubbing during the wash cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 12, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Loud noise during spin cycle
what kinda noise, sqeeling, or clunking, mite be sumthing small that made its way behind ajatator an is causeing noise..or one of the springs that hold it broke..sorry i dont no what kind of noise.....
Jan 31, 2010 | Washing Machines
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
85 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
