Question about Motorola Radio Communications
Gm3188 mobile radio
When I switch on my Motorola gm3188, it powers up but there is no sound coming out. What is wrong with it ?
  • Motorola Master
  • 1,654 Answers
This could be one of a variety of problems:
1. Bad speaker
2. No receive
3. You are on an unprogrammed channel
4. You have a bad volume potentiometer (dead spot in the on/off/vol)
5. Another internal issue
Try going to monitor mode and see if you can hear the white noise typical of being on monitor. If not, you could have problem 1, 2 or 4.
Try adjusting the volume and see if the radio works at a different volume level. If so, you have a problem with the volume pot.
Best regards.
Posted on May 08, 2014
Motorola t5720: Why does my radio show 0.5 watt icon even when i am using the 1 watt channel?
It is possible the manual is wrong where it explains channels 1-7 (GMRS/FRS). When checking on line sources your example frequency on Ch 7 of 462.7125 is limited to .5 watt. http://wiki.radioreference.com/index.php/FRS/GMRS_combined_channel_chart
With this in mind the icon on your radio is correct, and the manual is wrong on page 19. http://shop.giantintl.com/Manuals.asp?
Best regards.
May 24, 2015 | Motorola Talkabout T5720 (7 Channels)...
Magone bpr40 - How do you remove the Board from Metal back plate. All Screws are now off of board, But still not coming apart.
Great question! Clear and easy to understand! The volume and channel switches likely have a metal "O" ring that screws down on the threaded switch and holds the top of the radio to the housing. Remove the knobs, then use a really small flathead screwdriver, insert it into a notch in the "O" ring and unscrew. Be careful and you should be fine. If not, get it to a radio repair shop.
Apr 16, 2015 | Motorola Mag One BPR40 Two Way Radio
How much current does the Motorola T5720 2 way radio push out?
The radio puts out .5 or 1 Watt of power. Battery current draw is not available.
Feb 24, 2015 | Motorola Radio Communications
What are the default PL codes for the Motorola VL50?
I don't have a VL50, but a CLS is frequency two, code one. There is a way to reset to Factory default: press & hold PTT switch and the Monitor as you turn it on. If I got it wrong, try the scan switch instead of monitor. How this helps, if you want the actual numbers, post again please.
Feb 11, 2015 | Motorola Radio Communications
How do i program my 10x radios to work with my talkabout distance radios
I posted to your last request. The 10X uses dip switches and not the PTT to program. Here is the link again:
http://www.motorola.com/mdirect/manuals/DistanceDPS_User_Manual_E.PDF
Nov 30, 2014 | Motorola Radio Communications
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
My motorola GP900 has problems
Check for a bad antenna, wrong antenna, or no antenna. Switch antennas with a known good unit and see if the problem persists. If this does not solve the problem, you most likely have low transmit power, and the radio needs to be serviced.
Oct 17, 2008 | Radio Communications
Troubleshooting gm338
I have problem with my Motorola GM 338, if low out put (16w) may I ask you for the solution...
thanks a lot
Apr 17, 2008 | Radio Communications
Motorola spectra
Those should be for the speaker.
Jan 19, 2008 | Radio Communications
No sound for phone; problem with fm radio
I have seen a similar problem in other devices. Your description led to a suspicion about the earphone/mic jack. When you insert the lead, it displaces a switch that simultaneously turns the built-ins off and the external on. These can bend outwards or stick in the out position. (The "switch" I mention is usually a strip of metal you can see inside the socket.) Attempts to correct this are all at your own risk. You could try a drop of electrical cleaner and some plugging & unplugging.
Nov 18, 2006 | Microsoft Windows Mobile 2003 for Pocket...
Radio Communications Logo
70 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
