Question about Posiflex AURA PP6800 Direct Thermal Printer - Monochrome - Desktop - Receipt Print 5.91 in/s Mono - LED
Unable to connect: incorrect log on parameter
Error in file:c:\\DOCUME~1\ADMIN\LOCALS\TEMP\
Constant crashing while using any applications that is sound heavy, files involved are located in a temp folder under the user directory .dmp and .xml, specifics have been added to the add details
Unless you have a very fast HDD, the files need to be on a solid state drive. The other option is to have enough installed RAM so the HDD is not accessed.
Jan 29, 2016 | Computers & Internet
Setup has detected that the file 'C:\DOCUME~1\Jennifer\LOCALS~1\Temp\VSD335.tmp\SQL Server Compact Edition\SSCERuntime-ENU.msi' has changed since it was initially published.
Hi Remove you Temp file and installation again, now you did not get this error.
How to Remove Temp file
1) Go to Run and Type %temp% and press enter
2) Temp window will open select all and press the delete
Thanks
May 24, 2012 | NEAT Receipts Mobile Scanner
C:\DOCUME~1\user\LOCALS~1\Temp\27f2_appcompat.txt
Please delete all the file from Temp folder.
Dec 06, 2009 | Microsoft Windows XP Professional for PC
Error report...XP Home SP 3
The hard disk maybe is starting to crash or try also replacing the PATA or SATA cable that you are using, it maybe a faulty cable or something... have a nice day!!!
Aug 10, 2008 | Microsoft Windows Xp Home Edition English...
The problem: C:\DOCUME~1\GDMCDA~1\LOCALS~1\Temp\WER490dir00\mini070808-02.dmp C:\DOCUME~1\GDMCDA~1\LOCALS~1\Temp\WER490dir00\sysdate.xml I believe microsoft Internet Explorer does not work wee with AOL...
the firs hing to do here is goto your Temp folder and delete all files then if you are using ie6 then upgrade to ie7 as AOL is more happy with IE7 run AOL to log in to their server thn minimize AOL explorer then run internet explorer this should bupass their security measures that block you brouwse other sites.
happy webbing.
Jul 09, 2008 | HP Computers & Internet
System failure
Reinstall the media player.Also delete the temperory internet files. That will cure your problem.
May 24, 2008 | Compaq Presario X1000 Notebook
Compleate updates not done
First Scan u'r PC with a good antivirus(Should be updated to latest).
Check Internet connections.
If still not... Then make repair with OS cd.
Dec 26, 2007 | Computers & Internet
Posiflex AURA PP6800 Direct Thermal Printer - Monochrome - Desktop - Receipt Print 5.91 in/s Mono - LED Logo
18 people viewed this question
Top Posiflex Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Posiflex Office Equipment and Supply Expert? Answer questions, earn points and help others
