Question about Braun HT600 2-Slice Toaster
I bought a Braun toaster (lightly used) but only one side of coils turns red when heating. Is there any simple fix to this, or is it a discard? Thanks very much!
Toaster left hand side toaster does not stay in the down position but the element does heat up. This applies to all selection made and the red light selection comes on
It sounds like to me that the spring lock mechanism is worn out, here is a site to check out that will help you trouble shoot and even able to possibly fix it.
http://home.howstuffworks.com/toaster.htm
Please let me know with rating and some kind words if my free help was useful. Thanks Mike
Oct 30, 2011 | Kitchen Appliances - Others
The toaster (upper) part of our 4-slice toaster oven model 6067 suddenly stopped working after several months of using it consistently. Will return it to Target but hoping it's an easy fix. We kind of like...
Hi there. I just repaired mine. The wire connected to left side (as you are looking at the front of the toaster) of the front top heating coil had come off. I replaced all four of the crimps going to each side of each of the top two heating coils as well as the wire going between the front and back coils on the left side. Make sure that you use HIGH TEMP crimps and HIGH TEMP wire. I had the crimps and purchased the wire from a ma and pa repair shop here in my town1_24_2012_10_47_09_pm.jpg
Jan 01, 2011 | Sunbeam 6067 Toaster Oven with Convection...
I was given this toaster as a gift from my daughter. It failed after being used 4 times. Being a retired electronics engineer, I took the unit apart and found that a small relay that operated the toaster...
Unfortunately this is the sadddest part of our enviourment problem but the best part for the economic boom. Unless the unit is discarded the companies cannot surrvive.Hence most of the models are scrapped for no reason to make way so that the product sale continues.
If by cleaning the relay the fault can be rectified , try to do it with a good contact point/switch cleaner.
If the relay coils are damaged, the use an external relay if a similar type is not available.
the last option is to source one from a damaged set, sets discarded for coil failure etc..Try to salvage this part from old service shops,junk yards or second hand dealers.
Hope you find my tip helpful.
Aug 22, 2010 | Back to Basics TEM-500 Egg & Muffin...
Broken ceramic tube that contains the heater coil in my toaster
take it in to an appliance repairs shop and have it fixed proeprly
Mar 07, 2017 | Cuisinart CPT-50 Heat Surround Toaster
The coils (heating) do not appear to be working Tost comes out warm but not brown!!!
Inside your toaster there are four heating element plates two in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Mar 27, 2010 | Dualit 20247 2-Slice Toaster
Sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
169068 GE Toaster Oven - no heat
remove the plastic side where the controls are . if you see a broken wire you might be able to repair it otherwise theres no parts made for it ,so no matter how simple the broken part is .....there is nothing that can be done about it ........ WELCOME TO THE WORLD OF "MADE IN CHINA"
Jan 28, 2009 | GE 168947 Toaster Oven with Convection...
Krups 296 Toaster Oven will not heat
Fusible link inside the unit is probably broken.
Nov 24, 2008 | Krups 296 ProChef Ultra 1500 Watts Toaster...
T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
May 01, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Braun HT600 2-Slice Toaster Logo
127 people viewed this question
Top Braun Kitchen Appliances - Others Experts
Oscar Netto
Oscar Netto
Tom Chichester
Are you a Braun Kitchen Appliances - Other Expert? Answer questions, earn points and help others
