Question about Kenmore Oasis HE 27062 Top Load Washer
After replacing drive shaft with bearings and seal, RPS sensor and harness, and suspension rods, I still get F54 accelerating to normal or fast spin. What is going on?
First I started with an issue agitating. I replaced a bad RPS sensor and wiring harness, replaced drive shaft, bearings, seal, sleeve and thrust washer for water under the unit. Also replaced suspension rods. The unit will spin ok on low RPM but on 500 or 1000RPM as it accelerates to a fast spin, it errors out F54. I did notice some electrical noises coming from the motor getting to speed. The tub starts to sway while spinning the load, then the F54 comes back. I did notice some cracks in the stator assembly, After changing all these parts, my wife did 2 loads without problems. Later that evening, the next load she ran errored out F54 again on Express wash 27 minutes left on timer. Any ideas? I ordered a motor and stator assembly from e-bay...
SOURCE: Kenmore Oasis HE Washer
problem started when washer started itself up twice in the middle of the night....after that the washer seems to have problems figuring out what it wants to do...when running a wash it will start, run for 2 minutes then start scanning numbers...it does not land on a code...it will spin, stop, start...sears has replaced the mother board 3 times....and we will be phoning them again as it has not fixed the problem..one other time it did not spin properly and clothes were wet...we have a dedicated surge protector on it...we have had our electrical checked and no problems there...sears confirmed that as well..the techs have given up on it and don't know what to do with anymore...it is still under warranty and now costing sears more to service it then replace it....time for them to do the right thing and "take it back"...very disappointed in this washer...wish me luck when i call them again...they must be sick of hearing from me....lol
Posted on Apr 26, 2008
SOURCE: Kenmore Oasis HE Error Code F50
can be motor speed control board
Posted on May 15, 2008
  • 63 Answers
SOURCE: Kenmore Washer makes noise at start of the Spin Cycle
its your basket drive or sometimes called brake spin tube also comes with new clutch, ,transmissions wouldn't make that noise in only beginning of spin. your on your way to being a repair tech good job
Posted on Nov 12, 2008
  • 185 Answers
SOURCE: Kenmore series 80, model 110-25842400, and serial
thabks for being through... i wish everyone was like you.. i get alot of Its not working? i hate that what does that mean... wish they were like you.. please check the harness on the motor while it is spinning.. i had that problem before... also it could be the speed selector switch.. sometimes it will get caught running 2 speeds at once and it will click like that...
checks these things and let me know if you need more assistance.... you sound like a tech.. wanna job? lol
Posted on Apr 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis Wash Machine Error Code F54
The F54 fault code indicates that the control board senses high motor current.
This can be caused by excessive friction in the spin basket.
With the washer off, open the lid and see if the basket spins freely.
If not, you may need to remove the basket and check for an item stuck between the spin basket and the outer washer tub.
The second and third images show procedures for removing the basket on the Oasis washer depending on whether you have an impeller or agitator in your model.
If the basket spins okay, then you can follow the technical troubleshooting described in the first image.
This may help you determine the cause of your washer problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Removing Tub, Basket, lint filter: http://media.fotki.com/1_p,srfssgbktsdgrrqxgtqsskgwtqkq,vi/rstsfdwbbxwwdskwfgkxrrdqddwqb/1/1303472/5961857/image5139789143943268173img-or.jpg
Removing basket & Hub: http://media.fotki.com/1_p,sqgwstkfwtfwsqwxgtqsskgwtqkq,vi/kbkbfbkgwxbfdtwrdxkrkggrdrw/1/1303472/5961857/image27197img-or.gif
Wiring Diagram: http://media.fotki.com/1_p,srfssgbdfbbkfwsxgtqsskgwtqkq,vi/rstkrrqkkxwrtdkbbrbxbqdswfffs/1/1303472/5961857/image3973684248966800668img-or.jpg
http://media.fotki.com/1_p,wktkgtrtsbsgwfrxgtqsskgwtqkq,vi/wrskkfsfrxwwqgrkddg/1/1303472/5961857/image35809img-or.jpg
Posted on Sep 25, 2010
Airplane noise during spin cycle
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Apr 14, 2015 | Washing Machines
Why does my washer make extremely loud noise on spin and looks like the drum has fallen down?
It sounds as if something mechanically serious happened. Call a repairman and get a diagnosis. It may be a simple repair, but it is more likely to be a difficult and costly one. You have to decide.
Feb 23, 2015 | Maytag Neptune MAH5500B Front Load Washer
My washer has begun making a LOUD whining/whirring sound in the spin cycle.
Oct 01, 2014 | Whirlpool WTW6400SW Cabrio Washer
Washing machine will NOT complete rinse/spin cycle due to drum instability at high speed. At low speeds it completes the rinse/spin cycle about 50 percent of the time.
As a Whirlpool Tech this one drives us crazy the machine stops due to thinking the load is unbalanced the main computer reads the amp draw on the motor in spin any kind of resistance or drag will increase amp draw and shut down machine did he pull the basket to ensure nothing between basket and tub, I have found the Teflon balls that hold the suspension rods do not rotate due to rust the tech could be right a bad hub bearing could cause this you would normally get a high pitch sound in spin a bad RPS rotor position sensor will cause this any rust between the rotor and stator ( motor assembly ) will cause this, loss of fluid in the balance ring on the basket will cause this a loose balance ring will cause this and a bad control will cause this not reading proper amp draw I guess in saying I have replaced the parts the tech recommended and it did not correct the problem just those parts alone with labor is not cheap the best tech in the world unless some thing just stands out is making an experienced guess
Sep 04, 2014 | Whirlpool WTW6600SW Top Load
My washing machine makes an excessive clicking aand thumping noise. is this normal
Jul 30, 2014 | Whirlpool Washing Machines
Spin cycle is loud
Jul 01, 2014 | Whirlpool WTW5550X Washer
F54 code after repair
Okay F54 is a motor over current doubt if bearing was original problem this a rotor stator setup you should get a little resistance with the motor installed since the rotor has magnets, this code can drive you nuts there could be a crack in the rotor magnets are they rusty did the original seal leak,check the stator resistance on the control board ohm out the 3 wires on terminal P5 1 to 3, 2 to 3 you should get 31 ohms +/- 5 to get into diagnostic make sure machine is off use any button except power, start,stop, pause/cancel press and hold for 3 seconds, release for 3 seconds do this till 88 displays press the same button within 5 seconds of 88 should hear a beep you are now in manual diagnostic slowly rotate the basket the wash, rinse and spin light should flash as you rotate if all of the checks are good you have either a bad rotor or a bad control hopes this helps.
Jan 29, 2014 | Whirlpool Washing Machines
Daewoo DWD L142kc wont spin
Dwd-L142KC has a direct drive motor. A very common fault on this machine is that the drum shaft seal fails, letting water into the bearings which then starts to rust and then develope severe play between the drum and the tub. As the stator is mounted onto the tub and the rotor is mounted onto the drum shaft the rotor can then, due to the worn bearing, move too far away from the stator. Because the sensor that detects the actual speed of the motor is mounted onto the stator assembly, the control PCB then no longer gets the feedback signal from the sensor hence the motor not running correct. You'll most probably see the motor only moving in short bursts, a the missing feedback prevents it from accelerating further. A bearing and seal repair will in this case resolve this problem. It did on my machine. If the shaft is heavily worn below the shaft seal, this will need sorted in order to prevent the new seal from getting damaged or wearing out to soon.
Jun 08, 2012 | Washing Machines
Cabrio wtw6600sw2 f50 code.It spins freely.What now?
Any time you get a F-50 code on one of these, Whirlpool recomends you replace the control, wire harness, and RPS sensor if the tub bearing main shaft aren't binding.
Dec 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Disco II and the wheel hub bearing went and i'm tryign to change it but i cant seem to get the hub off, can any one help with a step to step guide or something, thanks.
RAVE says the following:
1) Release ABS Sensor harness grommet from inner wing valance and disconnect multi plug.
2) Raise front of vehicle.
3) Remove road wheel.
4) Pull ABS Sensor harness through aperture into wheel arch.
5) Release harness from brackets on inner wing valance, suspension turret and front hub.
6) Release stake from drive shaft nut
7) Remove drive shaft nut with assistance & discard.
8) Remove front brake disk (Remove calliper, pad holder, screw and tap to remove)
9) Remove 4 bolts securing wheel hub to steering knuckle.
10) Release wheel hub from steering knuckle then remove wheel hub and drive shaft assembly from axle. DO NOT REMOVE ABS SENSOR FROM HUB. HUB AND SENSOR ARE SUPPLIED AS AN ASSEMBLY.
11) Position the wheel hub and drive shaft on a press, place supports beneath the wheel studs and press the drive shaft from the wheel hub.
12) Remove drive shaft oil seal from axle casing.
Refit is mostly the reverse, you need to take care to lubricate things in the right places and put loctite on the drive shaft and locate the loom and torque everything right.
Mar 24, 2009 | 1999 Land Rover Discovery
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
