Question about Remington Shotgun Mount 12Ga Lh, B Square 16801, 870, 1100, 1187 12ga In Catagory: Optics, Rings, Bases and Mounting Systems, B Square Rings, Bases and Mounting Systems, B Square Shotgun Saddle Mounts
Remington Peerless 320 #RP002899 this gun has started to open when it is been fired.Cleaned action problem stopped for a short period and is opening again.what parts need replacing.
3 Suggested Answers
  • 23 Answers
SOURCE: i need to know how to assemble a remington 870 shotgun
The bolt has to go into the reciever form the front. It is inserted with the dog. This is a pain, but the bolt, dog, and action arms(from the pump) have to come together and be held just right to slide into place.
Posted on Aug 25, 2009
  • 5 Answers
SOURCE: I bought a Remington 870
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Posted on Apr 07, 2011
Need info on Remington Model 12 serial 799167
Description: Slide-action, solid-breech, hammerless, takedown, side-ejection rifle. Introduction Year: 1909 Year Discontinued: 1936 Total Production: Approximately 832,000 Designer/Inventor: J.D. Pedersen Action Type: Slide-action Caliber/Gauge: 22 short, 22 long, 22 long rifle Serial Number Blocks: Starting: 00001
Ending: 820,759 Grades Offered: 12A Basic Model
12B Gallery Special
12C Target
12D Peerless
12E Expert
12F Premier
12C N.R.A. Target Grades
12CS, DS, ES, FS chambered for .22 Rem Special cartridges and quality of finish Variations: none
Apr 27, 2015 | Optics
Rim or Centre fire
If it will be your first gun then rimfire as its cheap ammo so can get lots of practice . low recoil and great for learning the basics of shooting
Centerfire is more powerful and can shoot farther so can be used on larger game but ammo is that little bit more expensive depending on calibre used
So it comes down to what you want out of your shooting what rimfire does at short ranges centerfire does at longer ranges ballistically speaking
Mar 11, 2015 | Optics
Water switch open , heater heats up for short period and cuts out
ensure pump is running at full prime. clean the filter out as well. disconnect both connections from pressure switch in raypack heater. check continuity. if switch opens at any point and you have no flow restrictions then replace the pressure switch
Mar 11, 2014 | Solar Rheem Gas Fired Pool & Spa Heater...
Remington 35 portable forced air heater parts
Top cover is shorting out the spark plug wire.
Jan 10, 2014 | Heating & Cooling
Remington 1100 wont eject or load another shell
check and see if the shell stop hasn't broken loose. this on the inside left side of the action . this could stopping the next shell in the mag. from being loaded. this not uncommon. but is an easy fix. a gun smith can stake it back in . in a few minutes for around $20.00
Nov 25, 2012 | Remington Shotgun Mount 12Ga Lh, B Square...
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
Feb 02, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
My passcode is not opening my remington express gunsafe. I have tried holding the poles of a 9 volt battery to the metal area under the keypad but it does not work. What can I do at this point?
Gunsafes are meant to be difficult to open. I'm unsure as to your logic in the novel use of that 9v battery, all it would have done was to short circuit the battery.
Remington's own website gives you only one option if you're a US resident, "Contact Liberty Safes, the licensee, at 800-247-5625 for assistance with obtaining the combination to your safe.
If your safe is a low cost model and you need access quickly then you'll have to cut the safe open, but more expensive models are resistant to this form of attack and the safe will need to be scrapped and replaced afterwards.
Sep 27, 2010 | Locks & Locksmithing
New 870 express is not cycling low base shells properly
When it stove pipes, does the empty get caught by the next live round coming up on the carrier?
Try firing one round in the chamber and none in the mag and pump like normal.
If it fires and ejects the empty with no ammo in the mag the ejection system is probably fine.
If when you shoot with one in the chamber one in the magazine and it stove pipes you may have a timing problem. The cartridge stop is letting the next shell come into position and start coming up on the carrier to early. This may be fixed by moving the ramp on the action bar so as to get ejection farther along before the next shell is released to the carrier.
Caution, if the cartridge stops are ok and the carrier is coming up to early it is another issue altogether and needs to be looked at by a smith.
Sep 18, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Remington 1100 12 gage won't load a shell from the magazine
Are you shooting very light load?
Have you tried different ammo?
Light loads may not produce enough energy to work the action properly.
If different ammo doesn't help, make sure the two holes inside the barrel ring are clean and gas from the barrel can pass through. Next I would check the o-ring for cracks. If you shoot lots of shells (competition clays) the recoil springs inside the stock or over the magazine tube may have become weak and need replacing.
Jan 12, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
I need to know how to assemble a remington 870 shotgun
Nov 22, 2008 | Remington Side-Saddle 6-Shotshell Holder...
Remington Shotgun Mount  12Ga Lh, B Square 16801,  870, 1100, 1187 12ga  In Catagory: Optics, Rings, Bases and Mounting Systems, B Square Rings, Bases and Mounting Systems, B Square Shotgun Saddle Mounts Logo
49 people viewed this question
Top Remington Cycling Experts
Piyal Perera
Piyal Perera
raysaw
ray gallant
Are you a Remington Cycling Expert? Answer questions, earn points and help others
