Question about Remington Shotgun Mount 12Ga Lh, B Square 16801, 870, 1100, 1187 12ga In Catagory: Optics, Rings, Bases and Mounting Systems, B Square Rings, Bases and Mounting Systems, B Square Shotgun Saddle Mounts
What causes gun to open when firing Remington Peerless 320 #RP002899 this gun has started to open when it is been fired.Cleaned action problem stopped for a short period and is opening again.what parts need replacing.
  • 23 Answers
SOURCE: i need to know how to assemble a remington 870 shotgun
The bolt has to go into the reciever form the front. It is inserted with the dog. This is a pain, but the bolt, dog, and action arms(from the pump) have to come together and be held just right to slide into place.
Posted on Aug 25, 2009
  • 23 Answers
SOURCE: Remington 1100 12 gage won't load a shell from the magazine
Are you shooting very light load?
Have you tried different ammo?
Light loads may not produce enough energy to work the action properly.
If different ammo doesn't help, make sure the two holes inside the barrel ring are clean and gas from the barrel can pass through. Next I would check the o-ring for cracks. If you shoot lots of shells (competition clays) the recoil springs inside the stock or over the magazine tube may have become weak and need replacing.
  • 23 Answers
SOURCE: New 870 express is not cycling low base shells properly
When it stove pipes, does the empty get caught by the next live round coming up on the carrier?
Try firing one round in the chamber and none in the mag and pump like normal.
If it fires and ejects the empty with no ammo in the mag the ejection system is probably fine.
If when you shoot with one in the chamber one in the magazine and it stove pipes you may have a timing problem. The cartridge stop is letting the next shell come into position and start coming up on the carrier to early. This may be fixed by moving the ramp on the action bar so as to get ejection farther along before the next shell is released to the carrier.
Caution, if the cartridge stops are ok and the carrier is coming up to early it is another issue altogether and needs to be looked at by a smith.
Posted on Nov 04, 2009
agent91
  • 2100 Answers
SOURCE: I have a feed problem with my Remington 1100.
You have a shell stop that is either bent or worn, I think there are 2 in there, would have to look. Go to Gunparts.com for the view and order parts, might find them on ebean. Hope th is helps.
Posted on Mar 14, 2010
  • 5 Answers
SOURCE: I bought a Remington 870
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Posted on Apr 07, 2011
Where can i get a firing pin for a Remington 788 / 22-250
I would think that any gun shop should be able to help you locate one of these.
Feb 18, 2017 | Remington Health & Beauty
Hitachi nail gun
If gun firing but nails not being driven could be one of two basic problems:
1. Nail jammed in magazine not allowing nails to move up.
Empty magazine, does follower move to top of magazine. Push gun against work piece, does fan motor start? Yes - jam in magazine or lock out bar not operating. (this would allow nail un to fire when out of nails)
2. Piston/driver not returning fully after firing, hence driver blade on top of next nail instead of behind it. This could again be caused by a jammed nail or just a nail head. Another case of not returning is the combustion chamber not making a good seal, check O rings on framer (they are steel rings on bradders) it may just need a good clean it is surprising how dirty they can get and if not cleaned a build up of dirt could break a seal. If not been cleaned for a long time worth checking piston rings, worst case scenario dirt builds up around the rings and stick fully in requiring new piston if the rings will not come out.
Nail guns work on the principle that an explosion pushes the piston driver forcing a nail into the work piece, after the explosion a vacuum is created and it is this that 'sucks' the piston/driver back up the cylinder.
Mar 27, 2014 | Tools & Hardware - Others
Remington 1100 wont eject or load another shell
check and see if the shell stop hasn't broken loose. this on the inside left side of the action . this could stopping the next shell in the mag. from being loaded. this not uncommon. but is an easy fix. a gun smith can stake it back in . in a few minutes for around $20.00
Nov 25, 2012 | Remington Shotgun Mount 12Ga Lh, B Square...
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
Feb 02, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
Friend jus baught an older remington with the serial number 582793. Trying to figure out what ammunition it takes because it doesnt say on the rifle
It would help if you told us shotgun or rifle, center fire or rim fire, pump, falling block, lever, bolt action, or auto loading, etc.
Then it would help to simply see what fits into the end of the barrel.
Next would be to measure the length of the action.
After 1921 Remington use letter codes for year and month, so this would have to be earlier than that, since it has no letters.
Nov 01, 2010 | Remington Sport & Outdoor - Others
My alpha black paintball gun is shooting 1 to 5 then stopping.
Sounds like it needs to be oiled. A couple of drops in the small hole where your bottle screws on.
Replace bottle and dry fire to see if you got it. Cleaning is just as important. Internals need to be cleaned
and lubed often. I know it's late but hope it helps someone.
Jun 11, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
I need to replace a firing pin in remington 1100 20 guage and i dont know how to get to it
I know of a few sites that you should be able to order the part from: http://www.gun-parts.com/remingtonshotgun/, and the Remmington website parts page: http://www.remington.com/support/parts/model_1100.asp, and if you prefer they may have on gunbroker.com
Nov 29, 2009 | Remington Sport & Outdoor - Others
Sep 18, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Jan 12, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
I need to know how to assemble a remington 870 shotgun
Nov 22, 2008 | Remington Side-Saddle 6-Shotshell Holder...
Remington Shotgun Mount  12Ga Lh, B Square 16801,  870, 1100, 1187 12ga  In Catagory: Optics, Rings, Bases and Mounting Systems, B Square Rings, Bases and Mounting Systems, B Square Shotgun Saddle Mounts Logo
77 people viewed this question
Top Remington Cycling Experts
Vern Reece
Vern Reece
Level 1 Expert
raysaw
Are you a Remington Cycling Expert? Answer questions, earn points and help others
