Question about Lexus Vehicle Parts & Accessories
1999 lexus sc 400 problems can I splice a new oem 02 sensor to existing wires?
My #1 02 sensor is bad can I splice in a new denso sensor to the existing wires?
    New Friend:
  • 16 Answers
They make universal o2 sensors that come with connectors. they are also less expensive than direct fit.
Posted on Jan 23, 2015
    Problem Solver:
  • 14 Answers
Hello your question is a bit short on information, shooting in the dark here I am guessing you have the old 02 sensor out? If the connector
got damaged you can go right to NAPA and get factory type connector to replace the damaged one with. As a last resort you can carefully match each wire then reconnect them by soldering each one. Make sure you use small enough shrink tube and also slide it on the wire before you solder each wire so you can cover each one after its been connected and cooled.
Good luck and be safe.
Mark / aka RagenRat
Posted on May 12, 2014
Where is crank shaft sensor location on 95 lexus sc300 please help
images for Where is crankshaft sensor location on 95 ...
eplaced engine on '97 SC300 now new engine does not have Crank ...
www.clublexus.com/.../633233-replaced-engine-on-97-sc300-now-new-...
May 4, 2012 - Location: arizona. Posts: 3 ... apparently 95-97s had an additional crank sensor. .... 1995 Lexus SC300 5spd Na-T ( TT Ecu Mod + a few others) 2jzge position sensor??
Nov 2, 2011
SC400 Crank Shaft Position Sensor. WHERE?????
Oct 11, 2011
SC300 No Spark
Oct 2, 2010
What happens if the Camshaft Position Sensor goes bad?
Jun 18, 2009
More results from www.clublexus.com
Lexus Crank Position Sensor ' LS400 SC300 ES300 GS300 ...
www.partsgeek.com > Crank Position Sensor > Lexus Parts & Accessories
Products 1 - 10 of 68 - 95 1995 Lexus LS400 Crank Position Sensor Denso NLA 7/13 ... 96 1996 Lexus SC300 Crank Position Sensor Denso Includes Pigtail.
Jan 27, 2016 | Lexus Cars & Trucks
Lexus sc 400 problems
Replace the crank sensor
Sep 21, 2017 | Cars & Trucks
I changed the bank 1 sensor 1 and i still get the code p0135. i replaced it with denso. do i have to get the oem sensor?
The Brand of O2 Sensor is not the issue
The issue is you not knowing how to diagnose
the vehicles problems & how to use the codes you get
While codes sometimes indicate a part name & that
part may have failed,that is not usually the case
Need to Google the code & learn about it
It would seem you had a failed oxygen sensor
heater circuit & the new heater, if bad, wasn't the
only issue
Need to check the wiring next
Sep 13, 2013 | 2001 Lexus LS 430
Hello i have a 2001 pontica montana. I keep getting a code 420. I have change the cat twice and the plugs as well. What else it there to do?
Spark plugs or 02 sensors? The rear 02 sensor is what sets this code. The numbers it produces, how fast or how slow they come is how it tells the ECM that the catalytic converter is getting worn out. The sensors it self can be bad and cause the same code as a bad converter. Just a note bosch 02 sensors are not very good, I have replace 2 and 3 in a row that where new. Go with OEM or denso.
Aug 26, 2011 | 2001 Pontiac Montana
I have a major loss of power< car will drive but takes forever to get going, sounds very muffeled almost like its clogged or something, someone told me it could be the cat or the o2 sensor. this...
a bad 02 sensor won`t cause this type of problem as if it goes bad the pcm(computer) will use a stored value and set the check engine light on until the 02 is taken care of.sounds more like a possible collapsed exhaust system or the catalytic has come apart and part of it has plugged the exhaust.if this is the problem then it will have to be replaced.
May 01, 2011 | 1992 Lexus Sc 400
How do i reset brake ware indicator on my 1999 lexus ls400
The brake wear indicator is a small metal stone-like sensor that attaches to the brake pad. Once the pad wears down to a certain level, it begins wearing into the sensor, breaking the circuit open.
Once the light has come on, the appropriate sensor (front or rear) must be replaced to return functionality.
Factory brake pads usually come with new sensors. Aftermarkets do not, and often have no provisions for attaching them either.
Alternately, you can bypass the brake level sensors by splicing the two wires for the sensor together. You will no longer have brake level warnings if you do this however.
Sep 12, 2009 | 1999 Lexus LS 400
Check engine light
Sometimes can be prematurely dirty air filter, sets off the air flow sensor, which sets off the o2 sensor. So might try new air filter first and erase codes and then see, before you spend more bucks than you need; then if codes return, do the flow mix sensor.
Apr 19, 2009 | 2006 Honda Civic Hybrid
02 sensors for 2002 lexus es300
I bought online on Amazo for $48 each. The OEM is Denso. So I bought universal denso and I had to splice it. The part number is the same ecxept that is universal. So when you search, look for Denso.
Sep 28, 2008 | 2002 Lexus ES 300
92 lexus 02 sensors wire diagram question
i just checked the ford's..3 liter,12 valve....i see car has four o2's and all identical with heater inside.. i also found the lexus....i tried attaching a screen shot of each wiring..but size limits prohibit...i looked at wire colors...they don't agree ford to ford and lexus to lexus nor cross breed colors...on lexus are four pins..
pin 1 is heater
pin 2 is battery pos (looks like other end of heater filament)
pin 3 is sensor out
pin 4 is ground (possibly sensor)
on ford...
pin 1 is battery pos (looks like other end of heater filament)
pin 2 is heater
pin 3 is sensor out
pin 4 is sensor out
hope this helps...
Nov 11, 2007 | Car Audio & Video
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Lexus Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Hugh Mckernan
Hugh Mckernan
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you a Lexus Vehicle Part and Accessory Expert? Answer questions, earn points and help others
