Question about ASUS K8V-MX Motherboard
5kpl-vm asus mother board not detected new sata segate HDD how to resolve
  • Matthew Spark
    Matthew Spark Dec 28, 2014
    what size is the hard drive- gigabytes?
    Habit-Forming:
  • 89 Answers
The BIOS does not detect or recognize the ATA / SATA hard drive Tips and tricks for troubleshooting a Serial ATA or ATA/IDE internal drive that is not detected in the BIOS.
There are six main reasons why a system BIOS will not detect the presence of an internal hard drive. Here is a list of them. They are not in any particular order, but you can follow these steps one by one to troubleshoot this problem:
  1. Drive not enabled in the BIOS
  2. Serial ATA drivers are not properly installed
  3. Faulty or unplugged data cable
  4. Drive is not spinning up
  5. Incorrect jumper settings on the drive
  6. Faulty hard drive
Note: Sections 3, 4, 5, and 6 pertain to PC or Mac systems. Sections 1 and 2 pertain only to PC systems.
For more detailed step-by-step troubleshooting on this topic, please see the Seagate Serial ATA troubleshooter "Drive Not Detected" section.
After verifying that your ATA or SATA port is set to Auto-Detect or is enabled, if you find that your disk drive is not being detected (auto-detected) by the system BIOS, try the following steps to try and isolate/troubleshoot the problem.
  1. this link can be useful.
    System setup is where the date and time are stored and where startup preferences like NumLock or Passwords are defined. In addition, many hardware settings are defined in System Setup.
    In particular, hard disk drives are often controlled here. At the simplest level, hard drives are numbered in Setup as Drive 0, Drive 1, etc or sometimes as Primary Master, Primary Slave. Which ever way these are named, they have a basic ON / OFF setting (sometimes AUTOMATIC or something similar). If your drive is not detected it may be because it is turned OFF in System Setup.
    In most cases, the boot drive is Drive 0 or Primary Master. When you add a second drive to the system, it may be need to be enabled by turning it ON in System Setup.
    Sample screen shot showing a Dell System Setup section for disk drives:
  3. To be able to hit the F6 button, you must restart the Setup process, and watch the bottom of the screen after pressing Enter on the "Welcome to Setup" screen. There will be some moments of files being loaded, and then you should see a message appear that says "Press F6 if you need to install a 3rd party SCSI or RAID driver". This message will only stay on the screen for a couple of seconds, so press F6 as soon as you see it appear.
    (Click to expand)
  4. After this is done, you will see other messages appear, and it will act as though nothing is happening, but eventually a screen will appear that will allow you to install the drivers for the add-in SATA controller. The screen will look like the sample bel5kpl-vm asus mother board not detected new sata se - 48-3s.jpg
    (Click to expand)
  5. After you press S, the driver install process will continue and the floppy diskettes will be needed. Further instructions will 5kpl-vm asus mother board not detected new sata se - 48-4s.jpghed after the driver install process has ended.
    (Click to expand)
  6. Insert the floppy diskette containing the drivers for the add-in Serial ATA controller.
  7. Once the drivers are loaded, proceed with the normal Windows XP/2000 installation.
A few further notes on the driver diskette:
For the hard drive to be detected in a new installation, the drivers for the add-in SATA controller/motherboard must be loaded at the beginning of installation.
The drivers for the controller/motherboard can probably be found either on the CD that came with it or on the manufacturer's website. These drivers do not come from Seagate; they come from the motherboard manufacturer. Simply load the required drivers on the diskette and have it ready.
  • Document ID: 182453.
    Here are some images of Seri5kpl-vm asus mother board not detected new sata se - 48-7s.jpgbles. Click to expand.
  • The BIOS will not detect a hard disk if the data cable is damaged or the connection is incorrect.
    Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
  • The easiest way to test a cable is to replace it with another cable. If the problem persists, then the cable was not the cause of the problem.
  • For ATA drives, Seagate recommends using UDMA cabling with a maximum length of 18 inches. UDMA cables have color coded connections which require proper orientation when connecting.
    • Blue connector - always connects to the mother5kpl-vm asus mother board not detected new sata se - 48-5s.jpgi>
    • Grey (middle) connector - is used for slave devices on the cable.
    • Black connector - is used for master device connection.
    See this image:
    (Click to expand)
  • to determine whether it is providing sufficient electrical power to operate the drives and devices you have in your computer.
  • If the drive is still not spinning, connect it in another computer if possible.
  • Connect the drive in a SATA-USB enclosure or something similar 5kpl-vm asus mother board not detected new sata se - 48-8s.jpgle.
  • If the drive does not spin up after all of these steps, please visit the Warranty page to begin a warranty replacement order.
  • 48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -5kpl-vm -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA: It is recommended that all Seagate ATA har5kpl-vm asus mother board not detected new sata se - 48-11s.jpgpporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used.
  • SeaTools for DOS (see the tutorial here) to test the drive. If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
  • The BIOS does not detect or recognize the ATA SATA hard drive
    Posted on Jan 16, 2015
    • David Payne
      David Payne Jan 16, 2015
      VERY GOOD I LIKE YOUR STYLE OF TROUBLESHOOTING.
    sodeep
    • 3267 Answers
    SOURCE: Asus P5VD2-VM SE don't detect sata hdd
    What processor are u using & which OS have u installed? Try using WinXP_ServicePack-3.........sodeep
    Posted on Mar 20, 2009
    • 4 Answers
    SOURCE: Hard disk is not detecting when I try to install windows 7
    Hi
    You should find the drivers you are looking for on the Asus website.
    Here's the link to their download page,
    http://support.asus.com/download/download.aspx?SLanguage=en-us
    Hope that help,
    MK Support
    Posted on Mar 15, 2009
    jonb3838
    • 237 Answers
    SOURCE: ASUS P5S800-VM mother board V Asus EN9500GT graphic card
    you would need a new mother board or change the graphics card
    Posted on Feb 11, 2009
    Filidor
    • 28 Answers
    SOURCE: Asus K8VMX board didnot detect SATA hard disk
    Sounds like you just need to install your SATA drivers. Look around for your cd/floppy disc of drivers if you have any. When you boot from the CD, It will ask you if you have any other drivers you would like to install, thats when you install them and it should read your SATA hard drive just fine. If you dont have your driver CD anymore search ASUS's website or just google (or similar search engine) your motherboard and look for drivers. Beware of some phony sites though. Good luck :)
    Posted on Jun 17, 2009
    • 336 Answers
    SOURCE: Sata HDD NOT DETECTING IN XP SETUP
    If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
    If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
    Posted on Sep 11, 2009
    Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
    Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
    I suggest to review a few points detailed as under: -
    - K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
    - Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
    - Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
    - Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
    - Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
    Let me know if any further clarification/ assistance is required.
    Hope it helps! Good Luck!
    CreativeTECH
    Jan 27, 2011 | ASUS K8V-MX Motherboard
    Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
    You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
    This may be due to two problems
    1. Due to Virus
    2. Due to Insufficient RAM .
    You can mail for free remote Support for Viruses
    MSI RC410 - cannot detect Sata HDD
    i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
    Sep 20, 2009 | ASUS P5RD1-VM Motherboard
    Mar 20, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
    Hi
    Hope that help,
    MK Support
    Mar 15, 2009 | ASUS P5RD1-VM Motherboard
    PCI IDE slot does not detect hard drive
    Check if power cable to the HDD is connected properly or not.If it is connected then check the jumper settings on HDD.
    Thanks
    Mar 12, 2009 | ASUS P5GD1-VM Motherboard
    Could not detect HDD on my Asus P4B-M Motherboard
    hi,
    try removing with jumper behind the hard disk. and the see the cable or plugged in properly and do automatic detection of Hard drives in Bios
    Dec 22, 2008 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
    D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
    have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
    http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
    pls rate me FIXYA if ur problem is resolved
    Oct 16, 2008 | Intel D845GLLY Motherboard
    Sata DVD Ausus using K8V-MX
    TRy to load the "optimized bios default setting" in your bios setup. If not solve the problem maybe in your windows issue.
    try to boot up windows in safe mode and then start it normally and let the windows fixed the problem on it.
    if still problem exist maybe you need to repair your windows installation using the new SATA DVD to resolve problem regarding the issue. or reinstall it. (Note: important files was no guarantee to retain, backup files when doing this).
    note:
    Jan 06, 2008 | ASUS K8V-MX Motherboard
    ASUS K8V-MX Motherboard Logo
    174 people viewed this question
    Top ASUS Computers & Internet Experts
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
