Question about True GDM-26 Refrigerator
How to change light in gdm-26 pepsi cooler - True GDM-26 Refrigerator
4 Suggested Answers
SOURCE: True Refrigeration GDM-26 Compressor problem?
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's overload or capacitor may be out.
Posted on Sep 13, 2008
  • 7 Answers
SOURCE: We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Posted on Aug 13, 2009
  • 10 Answers
SOURCE: I have a True GDM-26. The contents get cool
I have same problem was told condensing fan not working properly. Easy to see if this is the problem, take out guard in front of machine and put a fan blowing into it. I went to home depot and bought a tornado fan and it cools again. Now if I can only figure out if its the fan or whatever contros its speed. If anyone knows how to check please respond.
Posted on Apr 17, 2010
Yesterday, I had a cook talk to someone about our reach in fridge door coming off ...i model GDM-26
Here is the parts list. http://beverageequipmentcompany.com/true/GDM%20Models/GDM-26%20Models%20Parts%20Listing.pdf
www.beverageequipmentcompany.com
Be advised that the hinge is a multiple part assembly with brackets, bushings, blocks ect. You might want to contact them to see what all you need
Apr 28, 2017 | Refrigerators
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
I have a True GDM-26, that I determined had a bad temp control. I ordered a new control from a company the referenced the part number by unit model number. I did not take the original control to match. ...
the temperature control you need is a part# 800386. the one you got(800393) is a temperature control for a 230 volt cooler not 115 volt. it is a 230 volt control
Aug 06, 2011 | True GDM-26 Refrigerator
I have a True GDM-26. The contents get cool inside but not cold. The temperature dial is set at the coldest setting. Also, there is a lot of condensation on the bottles inside the cooler. Any...
Nov 24, 2009 | True GDM-26 Refrigerator
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
I have a true GDM-12FC floral cooler that the compressor would not cycle. I just changed the thermostat but compressor would not quit.
You have not said if the cooler is cooling to the correct temperature or achieving the setpoint. Make sure that the correct thermostat has been supplied. Also that the sensor has been installed in the correct location. If all of the above is correct, then I would have the refrigerant level checked.
Mar 09, 2009 | True GDM-12FC Refrigerator
GDM-26 humidity very high
assuming fridge is at correct temp, i suspect fault is with your humidity detector. the humidity inside a fridge is a lot less than the outside air
Oct 09, 2008 | True GDM-26 Refrigerator
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's "Klixon" overload. Call a commercial refer guy (not somebodys brother in law that works on A/C, it's NOT the same!)
Jul 15, 2008 | True GDM-26 Refrigerator
True GDM-26 Refrigerator Logo
51 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
