Question about Insignia LCDTV26 26 in. Television
My insignia tv seems to be stuck on zoom the vol. and ch. do not work
Is there a way to troubleshoot to fix
    Top Expert:
  • Insignia Master
  • 75,311 Answers
It sounds that the main digital board has the fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Posted on May 08, 2014
Screen changes color from white - black - red - green - blue. The entire screen changes on it own. Nothing else on the screen.
push the vol up and then the vol down on the side of the tv or ch up then ch down, the set is stuck in a factory mode, this will clear it.
Aug 19, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
29agm2 how to access the servise menu
Hello
Check these proceedings and find out which porocess works with your Sharp TV.
* Unplug the TV
* Press and hold the {VOL -} & {CH+} buttons.
* While holding the above buttons, plug in the TV.
* The TV will turn on with the Service Menu displayed.
* There are 5 category menus:
Deflection - Signal - Feature - Fix Value - EEPROM
* Use {CH+} {CH -} buttons to select a category.
Note: Not all models will have 5 categories.
Some will jump to 'Signal' category.
* Use {VOL+} to enter the category.
* Use {CH+} {CH -} buttons to select the item to be adjusted.
* Use {VOL+} {VOL -} buttons to adjust the value.
* Turn the set off to exit the Service Menu.
LCD TVs :
* While the LCD is on, unplug the power cable.
* Then while pressing the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
* When it powers up you will see a little "k" appear in brackets.
* Then on the TV, press and hold {VOL -} & {CH -} down and release.
* The Service Menu will be displayed.
* Use {CH+} {CH -} buttons to navigate
Mar 22, 2011 | Sharp 29AGM2 29" TV
How do I do get to the set up mode using controls on the TV set? Want to do a channel search
Hello
To autotune do the following steps.
1.1 Press MENU to access MAIN MENU screen,
then press CH UP (8) or DOWN (9) to
move the " " mark to "SET UP".
1.2 Press VOL (+) or (-) to access SET UP
mode, then press CH UP (8) or DOWN (9)
to move the " " mark to "CH SETTING".
1.3 Press VOL (+) or (-) to access CH
SETTING screen.
1.4 Press CH UP (8) or DOWN (9) to move
the " " mark to "CH SEARCH", then press
VOL (+) or (-) to access CH SEARCH
mode.
START
2.1 Press VOL (+). The tuner will search
through all available channels in your area
and add them into the TV's memory.
STOP
2.2 Press VOL (-). CH SEARCH will stop at
the current channel and will not add any
higher channels.
2.3 Press MENU to exit.
Nov 21, 2010 | Sharp 25K-S180 25" TV
My TV zooms in and out. How can i change the zoom settings if the remote control is lost.
You need to clean front panel contact switches with contact cleaner,Power menu vol ch- ch+ .
Aug 19, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
I want to load my tv code from my vizio on my remote for my 321
I used 0178 to program my universal remote. You can also try 10056, 10178,10864,10885,11756,10056,11758, and 11499. Then you can try by dropping the "1" from the front of these codes.
Most good remotes have a programming function if this does not work, where the remote will "learn" the proper code.
The actual button remote codes are as follows:
0 00117
1 00121
2 00119
3 00123
4 00116
5 00120
6 00118
7 00122
8 00245
9 00249
Vol + 00183
Vol - 00187
Mute 00057
Channel + 00181
Channel - 00185
Power 00053
Enter 00164
Last 00247
Menu 00171
Guide 00244
Up 00168
Down 00166
Left 00170
Right 00037
OK 00164
Sleep 00054
PIP 00197
Info 00251
PIP Swap 00198
PIP Mode 00199
Exit 00216
Audio 00059
Input 00090
Wide 00138
TV 00110
AV 00105
Component 00231
HDMI 00174
MTS 00055
CC 00025
Zoom + 00165
Zoom - 00169
Freeze 00200
RGB 00253
PIP Ch + 00196
PIP Ch - 00203
PIP Input 00199
PIP Size 00201
Good Luck
Nov 30, 2009 | Vizio VW32L 32 in. LCD HDTV
Picture is in zoom mode and no remote is available. How do i reset picture
Press Menu on front of tv then use your CH- CH+ and Vol- vol+ to be able to scroll up and down the menu use Vol+ & Vol- to adjust.look for picture prefences in menu.
May 27, 2009 | RCA D52W19 52" Rear Projection Television
AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Jan 24, 2009 | Televison & Video
Zone 2 issues
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
Aug 03, 2008 | Yamaha RX-V659 Receiver
Service menu
Have you tried replacing the EEPROM? It may have lost it's programming for that set. Stargazer
Apr 19, 2007 | Proscan PS36123 TV
Insignia LCDTV26 26 in. Television Logo
67 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
