Question about Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Why is my timer not counting down, and no heat?
Timer just stopped. Everything except heat works. Replaced timer and same problem.
  • 1,606 Answers
Make sure the vent and heater air intake are not clogged with lint. Also, check the gas pilot to make sure it is not blocked up with gas line sediment, and the ignitor is working properly. The timer is probably waiting for a signal from the flame sensor.
Posted on May 08, 2014
frankgant
  • 250 Answers
SOURCE: Maytag Neptune dryer timer won't stop
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Posted on Jul 08, 2008
SOURCE: Maytag Atlantis MDG6400AWW does not stop on auto-dry. Heats fine and timer was replaced to no avail. Time Dry works.
jchow: I am trying to fix the same problem with the auto-dry on this model. If you have found the solution, could you please post it ?
Posted on Feb 22, 2009
buffalonyman
  • 1865 Answers
SOURCE: replaced timer module. Dryer did not run.
Check the voltage across the timer motor, make sure that you have 120 volts. If you have 120 across the timer motor, then it is bad. Also check your wiring to make sure you have wires in right place
Posted on May 01, 2009
  • 1015 Answers
SOURCE: Cloths take way too long to dry. Heat is
You will need to check the dryer venting system for a restriction. If there is a restriciton in the venting system the dryer will get hot but the clothes will stay wet due to the moisture never leaves the dryer. First check the air flow at the vent exit located outside. Verify that there is plenty of airflow. Make sure the vent screen is not plugged. Then remove the screen and visually inspect for excessive lint. Then go inside and check the moisture vent hose behind the dryer. Verify that the vent hose is not kinked or restricted. Then remove the hose and clear out any excessive lint. Then check the vent opening at the back of the dryer for any excessive lint build-up. There is a vent cleaning kit that you can purchase from any home improvement store that you can use to clean out the venting system also. When you are done airflow should be good and clothes should properly dry.
Posted on Jan 22, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag Atlantis MDG6400AWW, timer stopped working
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 20, 2010
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
May 10, 2014 | Microwave Ovens
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
Does not heat up and timer not working?
send brand name and model number so i can help you,also if it's on time dry it should count down even without heat if you have it on more or less the timer will not move without heat.heat comes on until heater cycles off when the heat is off the timer will advance a little,when the heat comes back on the timer stops advancing,it will do this until the clothes are dry.
Sep 15, 2013 | Dryers
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
Everything is working except the timer is not
Suggest you replace the timer dial, this should do the trick.
Oct 06, 2009 | Whirlpool Dryers
Everything seems to work fine until you hit the start button than nothing happens except the timer starts counting down
If everything appears to be working normally, as you say the timer counts down, the light comes on, turntable rotates etc. then the problem will be linked to the magnetron not operating & not heating the food. This could be just a thermal fuse device which may have gone faulty but if it is a magnetron fault then the cost of getting this replaced can be expensive & it might be more economical to buy a new microwave. I would advise taking it to a local repair centre, one which gives free estimates to get a quote on a price.
Jul 27, 2009 | GE Microwave Ovens
My Kenmore drier won't stop now! Perhaps timer isn't working?
Hi there. this is a timer issue. it counts down but, the actual shut off dial embedded in the timer mechanism is damaged for some reason. replacing the timer assembly will correct this issue. there are two parts to a timer. One, it times and last, it initiates the shutoff. the second action is not working properly. to be sure, check the relay before you purchase the new timer.
I have also provided you with a complete manual set that you can access and print out if you would like.
Click here for your manual
Click here for your instructions Guide.
Mar 06, 2009 | Kenmore 84052 Dryer
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
Apr 16, 2008 | Kenmore 62702 Microwave Oven
GRP99
Everything you described is normal, except not heating up.
When you first plug it in, you will see 'dashes' that tell you it is getting power.
When you press the Power Button, the grill will start at the Default Temp of 300F and the Timer starts at 5 minutes. You now change the temp to what you want.
It takes 5 minutes to get your grill to your tempreature, so the timer should 'count-down' as the grill heats up.
As for not heating up, I think you will need to get that 'looked at' for repairs.
Mar 18, 2008 | George Foreman GRP99 Indoor Grill
Maytag Centennial 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
