Question about Polaroid a550 Digital Camera
Question When I put my AAA betties in my camera, the door wont stay shut. I have to hold the batty door in to use my camera.
    Sergeant:
    Champion:
  • 242 Answers
If it stayed shut before it will do again.
Take the batteries out. check for anything in the compartment, put them back in checking that they are the correct way round and fully inserted always spring end first then the little positive button last.
Push them carefully fully home and the door should shut.
Patience usually worked in the end.
Posted on May 08, 2014
The door that holds the batteries in will not stay shut i believe maybe where you slide it shut a piece of that might be broken is there anyway to fix that or do i just need to hold it closed and hope for...
Pull the batteries out and see if it will stay closed, if it does the batteries are installed incorrectly. If it still won't stay closed your options are to either tape it shut or get a new camera unless it is under manufacture warrenty still or you have an accidental damage plan.
Jul 28, 2011 | Olympus FE-210 Digital Camera
The battery door on my hp photosmart M525 cracked and will not stay shut, therefore batteries fall out. I used a piece of tape keep the door shut, but it is a nice camera and I want it to work the way it...
Okay, from what you are saying its the weight of the battery that makes the battery cover fall of so i would apply a little, emphasis on little bit of glue before i put in the battery to hold the battery in place so the battery stays in even when the cover is not in place, then find a more stylish way of keeping the cover in place, maybe A LITTLE glue to the ridges that the cover slides on will be enough, you wont have any problem prying both lose when you have to, A LITTLE, lol , Hope this helps..
Oct 27, 2010 | Cameras
Doors freeze up wont shut close after opening interior light then stays on
Look at the end of the door where the latch is located. The latch may have flipped to the closed possition when the door was open.There is a U shaped piece that when the door hits the post on the door jam it flips up to hold the door shut.If you can get the passinger door open you can see what it looks like in the open position. If this is the problem just hold the door handle like you are opening the door and with a srew driver or even your finger you can push than U piece back down.To keep your door from freezing shut try putting sone silicone spray on a paper towl and wiping it on the rubber door seal.Spray a little on the door latch as well.
Dec 28, 2009 | 2001 Ford Taurus
Door wont stay shut unless you push on it
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 23, 2009 | Refrigerators
Door wont stay shut
The door latch could be closed, in other words, the door thinks it shut into the striker. Take and hold the door handle open, like your trying to open the door, hold the handle out or up and at the same time open the latch, it may be stuck or closed...If that's not it, you may have to re-align the latch to the striker, the striker will come loose with a torx bit. Loosen it up, and move it around and re tighten, it's a trial and error deal, just keep trying different positions until if works right...
Feb 25, 2009 | 1998 Chevrolet K1500
Help??
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the above didn't work, then consider the following:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 15, 2008 | Canon PowerShot A620 Digital Camera
Type of batties
TRY RECHARAGEABLE BATTERIES...IF THIS DOES NOT WORK THEN YOUR CAMRA MADE A SHORT CIRCUIT
Feb 21, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Polaroid a550 Digital Camera Logo
26 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
