Question about Sony KDF-E50A12U 50" LCD HDTV
Why won't the HDMI work?
When I connect my laptop to the TV via HDMI and select HDMI as the signal input, there is neither picture nor sound on the TV. How can I get this to work?
  • 1 more comment
  • etrc_new May 08, 2014
    Hi Scot , if YOU switch you laptop so that it is dual display mode (on my HP press the f4 button) can you get anything on your laptop ? After checking connections, try a different HDMI cable. Do you mean selecting HDMI input on the TV (expect you do) ?
  • Scot
    Scot May 08, 2014
    Hi, yes I managed to eventually get a picture on both the TV and the laptop using the f1 function (I have a Dell XPS) and setting the Sony TV as the default display device. However, I am only able to extend the screen, not duplicate it, nor select 'projector only'. No matter what option I selected, it changed to 'extend'. I was still not getting any sound at this point though. I had also selected the Sony TV as the default playback device for digital audio, using NVIDIA control panel - all to no avail. Then, mysteriously, while I was out of the room, the sound appeared... Wish I could say what it was that solved the problem, but I honestly have no idea! It's still working fine now though, apart from not being able to select 'duplicate', rather than 'extend'.
    Some computers have a screen extendfunction yes. I believe this is different to the sitch display function that you need, although you might try (but you probably have already) pressing f1 more than once, because the exact function may cycle through a number of options. I would on the internet (again, if you haven't already) forswiching the display to an external monitor on Dell computers. I have been assuming that the HDMI connection is on your computer rather than any video card. The sound issue may have had a delay while your computer was respoding to your changes to the nvidia control panel, and it was just figuring things out, might have taken a couple of minutes. Sound may also be a function of your HDMI set-up.. These links show you what happens when it works (FN + F8 is the key combination); one shows you about the sound I believe. http://www.youtube.com/watch?v=httuIXjGz... and http://www.ehow.com/how_5544182_switch-e... . Another problem was caused by a faulthttp://commweb-ps3.us.dell.com/support-f... These are just the first three results I got from my internet search. I hope this helps, if you have't worked it out. 8.May.2014
SOURCE: 50" Bravia KDF-E50A12U
read about this last night see http://www.avforums.com/forums/showthread.php?t=384717&page=9
seems there is an easy fix
Posted on Jan 07, 2008
SOURCE: no signal when connected via hdmi to dvi on tv
ya nothing shows up is all black no sound nothing
Posted on Jan 09, 2008
davebies
  • 43 Answers
SOURCE: No digital to reciever??
This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
Posted on Jan 14, 2008
SOURCE: Input 7 not working
Did you go to "Label Inputs" in the settings? Make sure Input 7 is not set to "skip."
Posted on Jan 30, 2008
pazman
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
LG 60pk950 - HDMI inputs 'No Signal'
Try manipulating the TV mode selection to HDMI 1, 2, 3 or 4, whichever the number of HDMI ports are available.
Nov 02, 2015 | LG 60PK950 High Definition Plasma TV
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
Nov 26, 2012 | Protron PLTV3250 32 in. LCD Television
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
How do I convert from HDMI-in to Component-Out? Basically, I'd like to have my cable box (Comcast DVR) coming into the receiver using HDMI but would like to output to my TV using Component instead of HDMI....
looking at the manual here that should work for Video http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
it looks like on the receiver you would have the DVR connected via HDMI cable to the receiver On the receiver you would select this HDMI as the input. That should automatically allow that signal to be presented to the component out on the receiver you connect the cables from component out to the TV and switch the TV to select the component input -depending on the TV model this may be labeled AV1,2,3,4, etc No sound will be transferred to the TV as component is Image ONLY whats the make and model of the TV
Mar 20, 2010 | Onkyo TX-SR606 Receiver
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
No sound from tv
look for a hdmi input via the menu/ video /source button on the remote.[different manufactuers list them differently] if you have multiple input selections on the display,scroll thru each one,wait 2or3 seconds between each input and see if your picture comes on.also check the hdmi connection
wg
Feb 02, 2008 | Audio Players & Recorders
No signal when connected via hdmi to dvi on tv
Oct 27, 2007 | Sony Playstation 3 (PS3) Console
Sony KDF-E50A12U 50" LCD HDTV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
