Question about GE Monogram ZISS480DRSS Stainless Steel
GE monogram ZIS420D. freezer reading 17degs and
GE monogram ZIS420D. freezer reading 17degs and refer side reading 36degs. what do i need to do to get the freezer side colder. i have adjusted temp down with no change in temp in freezer.
  • 46 Answers
To much stuff in the frezzer?
Posted on Jun 26, 2009
GE monogram zis420d refrigerator is not very cold, but the freezer is fine
Usually the air transfers from the freezer to the fridge in the center of the back of the fridge and freezer areas. they are easy to identify, make sure the vents in both the freezer and fridge are not air flow blocked preventing cooler air from transferring to the fridge.
Sep 18, 2014 | Refrigerators
GE Monogram 42" Side by side frig- has power, but won't cool. Model ZIS420D, installed in 2004
Does the compressor run? Unplug it from the wall, locate the compressor quick disconnect. Set you meter to 250V clip or plug meter leads to compressor wires. Stay clear, plug in unit and turn on to full cold..should have 120V at the leads..if 120V there you need to test the compressor and or start relay to find the problem. If no voltage or low votage need to work backwards from the plug unit you do find 120V. Checking the t/stat and control timer etc.
Aug 11, 2014 | Refrigerators
Ice in freezer and warm refrigerator Zisb48dyb
If I remember correctly, GE had a issue with the drain pan as it would clog or restrict and back up in the freezer and in the air return (hence, water under crispers if refer section). GE has a repair kit for this and they have also changed the drain hose to prevent self restricting as it leaves the freezer. This part is an Icing kit part# WR49x10021, this comes with complete instruction as to what your changing and why. This should solve your drain and water problem, if this is what your issue is. I hope this was helpful.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 31, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Serial #
What problem are you having? All you need is the model number.
Jul 05, 2013 | GE Monogram ZICS360NRRH C... Bottom...
Temperature Cycles Inconsistently in Freezer and Fridge
Possible thermister our main board. Would need take readings at the board to see what the themisters are reading. If they check good then issue would be in main board
Aug 20, 2012 | GE Monogram Side by Side Refrigerator
GE Monogram ZISW36DYA ... frozen ice-cycle rivulets run down both sides of freezer (water off for days to verify it is not ice maker) ... defrost control clicks when rotated and advances with time ... do...
Seems to me that might be a clogged defrost drain or maybe a dripping water valve. Doing that. I have the service manual with nice pictures in it that show clearly how to access the components.
GE MONOGRAM SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 10, 2010 | GE Monogram Side by Side Refrigerator
Freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram ZISS480DRSS Stainless Steel Logo
963 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
