Question about Jenn-Air Refrigerators
Jfc2089hpr refrigerator crisper drawer replacement
  • Bailey's Appliance Service
    Hi Guy Priano, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Are you looking for one of the 2 smaller crisper drawers, or the single large (Hungry Hippo) drawer ? Be more specific as to your needs.
22yooper
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
SOURCE: Leaking Whirlpool refrigerator
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Posted on Nov 12, 2008
SOURCE: water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Posted on Jun 24, 2009
  • 2976 Answers
SOURCE: Refrigerator crisper drawers are freezing veggies
Shut the air flow into the crispers if you can. If not, turn the refrigerator temperature warmer by just a few degrees. The air into the fridge from the freezer is channeled into the crispers.
Posted on Jul 01, 2009
heatman101
  • 43501 Answers
SOURCE: Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 02, 2010
Bottom refrigerator crisper drawer slide fell off
draw slide is mounted to the shelf bracket --either order new bracket or remove bracket [look how slide positioned on other side ] and try drilling and putting in small screw and nuts till you can order a replacement bracket
Sep 09, 2016 | Refrigerators
How do i replace the small post that the crisper drawer rides on ?
you need a different site for this question this is a auto help site.
Sep 05, 2014 | KitchenAid Superba KSRG25FK Side by Side...
Water in left bottom crisper drawer
You need to get a replacement gasket for the make and model of the refrigerator, http://www.fixya.com/support/12355008-water_in_bottom_left_crisper_drawer
Jun 11, 2017 | Whirlpool Refrigerators
The middle support that holds up the crisper drawers has broken
Check with KitchenAid regarding replacement of the part. You also can try an appliance parts supplier as the tab may be a frequent failure item.
Nov 17, 2013 | KitchenAid Architect KBFA20ERSS Stainless...
Jul 01, 2009 | GE PFS22SISSS Stainless Steel French Door...
Water standing under crisper drawers
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
LG LRFD22850 Replacing support grid for bottom crispers in refrig. Need help.
It is a challenge to replace those grids.  Instead of trying to fit the support grids into the frame, bend the frame slightly to fit the grids.  You will need to remove the steel support from the frame before bending the frame.  That is what I have been able to do when I have those problems.
Oct 11, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
