Question about Daewoo Computers & Internet
I NEED APOWER CORD FOR DAEWOO L950 - Daewoo Computers & Internet
  • 1,606 Answers
I can't find information online about your monitor, so I'll give you a generic answer for all monitors.
Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters)
C13 image:
C7 image: ac15wna-r.jpg
C5 imagI NEED APOWER CORD FOR DAEWOO L950 - 173-21103-e.jpgc="http://i.fixya.net/uploads/images/173-21103-e.jpg" alt="173-21103-e.jpg" class="h_mi" />
These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors.
There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it.
It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
Posted on May 08, 2014
Where can I get a power cord
Alternatively referred to as a power cable, mains cable or flex, apower cord is the primary cable that provides power to the computer, printer, monitor, and components within a computer. In the image to the right, is an example of the power cord that is commonly used with computers, monitors, printers, and otherperipherals.
Mar 25, 2016 | Office Equipment & Supplies
I need apower cord for a singer 3116 simple
try sewingpartsonline.com
or premiersewing.com
Mar 17, 2012 | Singer 3116 Simple
I need a power cord for a Daewoo Portable DVD Player. (model #DPC-8400N
For the Daewoo DVD your best try would be to check with MCM electronics. They have a wide range of offshore parts and equipment. Or try your local Radio Shack
Sep 10, 2011 | Televison & Video
THERE WAS APOWER PROBLEM AND MY MICROWAVE COMPLETELY STOPPED WORKING.NO DISPLAY AND NO SIGN OF AN OUTPUT
Check the main fuse inside the oven on the floor of the cabinet near where the power cord enters.
I believe you will find it needs replacement.
May 27, 2011 | LG Microwave Ovens
I need an ac power cord for the daewoo monitor model # L523BM
Go to any say goodwill store or thrift store, the power cords they have any one should fit.
May 19, 2010 | Daewoo 17N5 17 in.CRT Conventional Monitor
I NEED A POWER CORD
This TV uses a standard power cable that is also used in many other TVs, monitors, and computers. It is a CEE 7-7, which is often called a 'PC power cable' or 'standard 3 prong power cable'.
You should be able to find them almost everywhere, but your local Radio Shack, Bestbuy, or Walmart are all sure to have them.
Jul 28, 2009 | Niko OTP-3211W 32 in. LCD Television
My computer cannot start
look at the back of the computer. there is apower selector next to the power cord.
change that from 240v to 110v.
Nov 18, 2008 | AMD M863G (M863G15CV22ARV000) Motherboard
I need apower cord for flat screen model# p701 name sl70011ms
usually the power cords are very standard... the power cord communly used has the 3 prongs and has a d shape female/male plugs... try the thrift store.. (I found one that i needed like that.. i had to unplugg it from an old monitor because I did not want to get the monitor so I paid like 2 bucks instead of 10... or just go to a computer store... they may have spares they can sell to you for cheap.
Sep 21, 2008 | Computers & Internet
Laptop
Try removing the battery pack and then power up with the cord. If it works, then it means that the battery pack needs replacing/recharging.
If it still dos not work, the cable could be faulty. Get it replaced.
May 15, 2008 | HP Compaq Presario C304NR Notebook
Computers & Internet Logo
107 people viewed this question
Top Daewoo Computers & Internet Experts
Michael Galve
Michael Galve
Saleem Baig
Saleem Baig
JonSnell Electronic
JonSnell Electronic
Are you a Daewoo Computer and Internet Expert? Answer questions, earn points and help others
