Question about Samsung CLX-2160N All-In-One Printer
Same problem, it print perfect on the right side but the left is getting worse and worse, it's seems to be a common problem with this printer, i think i'll bring it in for the warranty Kate
    Sergeant:
    Champion:
  • 253 Answers
Just clean ur cartriges heads and for more technial support contact us at http://tinyurl.com/mtgjzz
Posted on Jun 22, 2009
Brother MFC-9440CN Laser Printer knocking noise on startup and printing
Throw that piece of garbage out and get an HP or Samsung. One of these has plagued my office for years and I've spent countless hours plotting its demise. Worse than useless: unreliable.
Mar 25, 2014 | Brother MFC-9440CN Laser Printer
My rimage perfect image only prints half of a cd
Bad print head,
John Norman
Max Optical llc.
www.maxoptical.com
Jan 27, 2012 | Rimage Perfect Image Prism Thermal Printer
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
I have an HP Laserjet 5200 printer that prints very light on one side even when a new cartridge is installed. Replaced the fuser and rollers with maintenance kit about 5 months ago which improved some...
2 possible causes. Transfer roller problem....this is the roller that sits right under the toner cartridge and runs from left to right. Check to makes sure it springs back up when pushed down on both sides. Next is caused by dirty laser optics. This requires dis-assembly of the machine and should be done by a qualified tech. Dirty optics would be more of a concern in a dusty environment or if the printer has been used regularly for at least a year or more.
You are correct in assuming that if the problem was there before cartridge change and after with no change then the cartridge is not at fault.
Jan 02, 2010 | HP LaserJet 5200 Printer
Doesn't see print cartridge
there are some lock for cartridge in printer right side cover may need to be adjusted
check if its get lock when toner is slide in side printer
spring at RHS for lock need to be check
Nov 07, 2009 | HP LaserJet 3050 All-In-One Printer
Printer no longer prints legibly
My CLP-300 color laser printer does not print clear in black. The left side of the page is worse then the right side. what can be done to fix this problem
Oct 30, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Poor, faded print quality on left and right sides of paper
Have you check the teflon at the heater? have you clean the reflector of laser? Try that.
May 30, 2009 | HP LaserJet 8550 Printer
Epsom stylus c84 major lines thru pages. Already cleaned heads.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully
into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any black ink on the nozzle check, then there is hope! Repeat the process
until you get a full black nozzle check. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Mar 29, 2009 | Epson Stylus C84 InkJet Printer
Not printing on left side of page
The problem is that the revolving drum doesn't contact the OPC drum proberly. You have to open the left side off the machine and replace the little white gear on the shaft that drive revolving drum. The gear has "jumped"one step and the revolving drum isn't parallell to the OPC drum. I fixed my 2840 last night it takes some time but now it works perfect.
Feb 25, 2009 | HP LaserJet 2840 Printer
Samsung CLX-2160N All-In-One Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
