Bizhub c203 with c3421 error code - Office Equipment & Supplies
    Sergeant:
  • 231 Answers
Http://www.oasq.com/how-to-clear-error-code-c-3421-on-konica-bi-thread-733519-1-1.html
Posted on May 08, 2014
  • 165 Answers
SOURCE: Konica Minolta Bizhub c203 printer
where do u scan e mail or folder? if e mail your smtp server ip may have been deleted/changed if folder the path may have changed/deleted or password changed on the server/desktop
Posted on Apr 05, 2010
Bizhubman
  • 108 Answers
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
Posted on May 22, 2010
  • 22 Answers
SOURCE: My bizhub c203 wont scan
please reinstall your connectivety with copier
Posted on Nov 25, 2010
  • 118 Answers
SOURCE: how do i set my KonicaMinolta bizhub C203 to copy
set the copier on black then go to utility/counter, user settings then set current settings
Posted on Oct 16, 2011
  • 118 Answers
SOURCE: how do i replace the
it is behind the right door but i doesnt need to be replaced you need a pico fuse about
$2 and it can be reset. if yoiu need more help in this and where the fuse is just ask
After upgrading to windows 10, unable to scan doc from Konica C203 to PC
To help you troubleshoot the issue about unable to scan but able to print, it is recommended to try uninstalling the previous software and driver and re-install Konica Minolta BizHub C203 printer software and drivers from the link given below:
http://www.biz.konicaminolta.com/download/driver.html
If issue persists, you can find the troubleshooting link and check if that helps to resolve the issue:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C203&page=1
If issue persists, it is recommended to contact Konica Minolta bizhub for further assistance:
GuruAid.com
Jun 13, 2016 | Konica Minolta bizhub Office Equipment &...
Error code c-3421 in bizhub c220
Hi
The following site gives error codes for a wide range of printers and their user guides can be obtained as well.
Error Codes Konica Minolta bizhub C220 Code C3421
Your error comes up as follows:-
Code:- C3421
Description:- Fusing heaters trouble (Heating side)
• Detected temperature of the heating roller thermistor/C does not go up a given range of temperature even after a lapse of given period of time at warm up. • Detected temperature of the heating roller thermistor/C does not reach to a given temperature even after a lapse of given period of time after warm up is completed.
Remedy:- 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 6 Change PRCB. 7 Change DCPU.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 05, 2014 | Office Equipment & Supplies
How to repair c203 bizhub error code 5370
Cooling Fan FM-6 for the MFP board, rear of machine a small fan between to large fans.
filter clean?
DUST?
May 09, 2014 | Genuine Konica Minolta Konica Bizhub...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code 7255
no such code for the model c203
Mar 03, 2014 | Konica Minolta Bizhub c203 Copier
Error code c3201 bizhub c203
Fusing motor failure to turn remove the fusing unit. Check for proper operation. If the orange rollers are chewed up replace the fuser unit
try this place for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Aug 02, 2012 | Konica Minolta Bizhub C203
My konica minolta bizhub c203 will not send out faxes ng error code
you cannot have a VOIP line or FOIP line (like comcast or Vanige) it can only use a dedicated land line. i know this is aggrivating...
Nov 09, 2010 | Konica Minolta Bizhub c203 Copier
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
194 people viewed this question
jasbo
jasbo
