Want to connect 2 yamaha msr 800 w subwoofers with each other because the one speaker build in amp is not working can i
Want to connect 2 yamaha msr 800 w speakers with each other because the one speaker build in amp is not working can i co that
  • 4 Answers
If you want to do it the safe way so you don't put too much of a load on your amp, connect the positive wire from one speaker to the positive output from your amp. Then connect the negative wire from that speaker to the positive wire of the second speaker. Finally connect the negative wire of the second speaker to the negative output of the amp. This will get sound from both speakers without straining your amp. This is called wiring in series.
Posted on May 16, 2014
How do i connect ms 10 sub to yamaha RX-V1065 amp, I am using 2 monster cables.
The ms 10 is an active sub, so all you should do is connect the Subwoofer output on the rear of your amp to the LFE input on the sub with a simple audio cable.
Nov 27, 2011 | Mission MS10 Subwoofer
I have a yamaha yst sw320 subwoofer connected to a yamaha dsp-a595a amp. I recently disconnected my equipment and when i reconnected it im getting a feedback hum/noise through the sub. I've tried...
Subs don't go to a variety of connections on the amp. Let's stop guessing and stick with the prescribed one.
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Yamaha-YST-SW320-Subwoofers-manual/id/320bh340/t/2/
See page E1 regarding placement and safety.
http://www.retrevo.com/support/Yamaha-DSP-A595-Amps-manual/id/319ag821/t/2/
Page 44 - read about "humming".
If you have hum on the sub, is it there with and/or without the input cable attached?
Disconnect the input(s) and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
Mar 02, 2011 | Yamaha YST-SW320 Subwoofer
I have 2 10' sony xplodes connected to a 2
If your radio is still playing and the subs are giving you music, you most likely have the amp remote wire hooked to a constant power source on the radio. Generally, this is a solid blue wire on both the radio and the wiring harness. It allows the radio to turn the amp on and off when the radio is on or, subsequently, off.
Apr 21, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Wharfedale 10inch cude subwoofer that has a feedback hum when con
Hiya, try a different input cable (from amp to sub) if you have make sure that is ok.
Failing that if there is an earth in the plug, try to disconnect that (earth loop) - unlikely but hey electronics.... anything possible :)
If still there with new cable, earth off etc, then the Yamaha could have a problem but find that difficult to swallow...
Let me know if helps, see any other possibilty
Best of luck
Jul 14, 2009 | Wharfedale PowerCube PC-10 Subwoofer
I have an old yamaha ypa-800 amp i kneed an manual to know how much wattage it is running just 2 10in subs
I have a ypa 1000 and a ypa 300 and each says exactly how many watts it runs right on the top cover.
The 1000 is 120wpc x 2, the ypa 300 is 35 wpc x 2.
So pick a middle figure closer to 100 wpc.
Peace.
May 01, 2009 | Car Audio & Video
How do I connect a mac audio output to a yamaha sound projector?
NO!!! get a 3.5 male TRS to stereo RCAs to either the Aux input on the amp or the audio portion of the front A/V Aux. the audio jacks will be red and white.
Dec 04, 2008 | Yamaha Digital Sound Projector Home...
Yamaha YST-MSW10 subwoofer quits after about 10 minutes
This problem can be solved by either of the following:
1/ Modify the PCBA to prevent the auto shut off feature from working. This is done by adding a 20k ohm resistor across pins 1 & 2 on the timer IC6. This resistor will prevent the timer from turning off the amp. To do this, unplug the amp. Remove the 8 screws on the perimeter of the rear of the amp. Carefully remove the rear plate. Disconnect the speaker wires at the speaker and the front panel connection on the main board. Locate IC6 on the bottom of the main board. Solder a 20k ohm resistor (1/4W) across pins 1 & 2. Pin 1 and Pin 8 are noted on the board. Be sure to insulate the leads of the resistor to prevent contact with the board. See picture. Re-assemble in reverse order.
2/ Some 5.1 channel amps allow independent control of the volume for the subwoofer in their setup. Check your amp to see if you can raise the signal level going to the subwoofer to prevent the amp from shutting off. You can then dial back the volume of the subwoofer using the volume control on the front._436.jpg
Aug 07, 2007 | Yamaha YST-MSW10 Computer Speakers
81 people viewed this question
 Grubhead
Grubhead
