Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp 5816 1st Paper Tray not showing. - Sharp AR-5316 Advanced Digital Imager Copier
2 Suggested Answers
  • 32 Answers
SOURCE: Sharp AL-1631: Flashing H-4. Paper tray light is
H4 indicates that you have no power for your heater lamp. Either the thermostat or the lamp is open. For the thermostat, you can reset it if you know how to remove the fuser section and its cover so you can see the thermostat and reset from there. For the heater lamp, check its continuity using a tester.
Posted on Jul 23, 2009
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
How do i print 6 3/4 return size envelopes on a sharp 2600n
You have to select the Manual Feed Tray by touching the picture of the copy machine on the LCD screen. That will then show you the paper trays. Touch the paper type soft key for the Bypass/Manual Feed Tray and then select envelope. then press ok a couple of times till you are back to the main screen. Put your envelopes face down on the Bypass/Manual Feed Tray. If you are printing from a computer do the same thing after you go to printing preference/properties.
Oct 20, 2011 | Sharp MX-2300N Color Copier
It will not copy, the screen shows a P and it smells like it's running hot. What is the problem?
When this copier can not find paper by pass tray or casset then show it p .P mean add paper.Before you select paper tray then make a copy.Thanks
Tareq Bin Mostaq
Bangladesh.
Aug 13, 2011 | Sharp AR-5316 Advanced Digital Imager...
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
The printer is showing a "p" on the display. what does this mean?
The "P" means that you need to add paper into the paper tray or in the manual feed tray. Odds are that you are getting a paper jam from the paper tray? I would try to fill the paper tray with paper & make sure the copier is on a level surface. You may need the paper feed tire's or you may have a paper present sensor broken? I would just use the manual feed tray. Good Luck
Oct 17, 2010 | Sharp AL 1631 Copier
My photocopier sharp z810 is not accepting paper.how do i rectify the fault or problem.i need a solution please.
if there is paper in the paper tray but the machine still says no paper, then the paper end sensor is broken in the tray. take the paper tray out and you will be able to see a sensor on top. when the tray is fitted the sensor is on top of the paper. the paper lifts the sensor to activate. i am a photocopier technician.
Oct 01, 2010 | Sharp Office Equipment & Supplies
Do I use ink jet paper or laser paper in my Sharp MX-350IN copier?
Laser paper. You really can use a broad range of paper.And papers up to 120lb. Any paper heavier than standard stock (20lb) must be designated as heavy paper in the bypass tray and run in the bypass tray. Bypass tray is the fold down tray on the right side of copier
Apr 05, 2010 | Sharp MX-3501N All-In-One Printer
I have a Sharp AL-1642CL printer. It will not
Check the paper tray sensors or change the set to external by pas tray to paper tray.
Jul 14, 2009 | Canon imageCLASS D320 Digital Copier
Sharp mx 3500 won't recognize custom paper
In the printing properties, on the paper select tab, change the paper tray from automatic to by pass tray
Jun 19, 2009 | Sharp MX-2700N Color Copier
No paper alarm
Check cable connectors. Or check if the tray rises after it gets inside the copier, maybe you must stretch the springs.
Oct 12, 2008 | Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
15 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
