Question about Cobra Vehicle Parts & Accessories
I need to know how to put the cigarette lighter adapter back together
The end of my adapter came out of slot in peices
  • 776 Answers
Buy a new one. A spring or part of the connector likely fell out when it split open. They only cost $5 or, go to Goodwill and get one for a buck.
Posted on May 08, 2014
4 Suggested Answers
  • 347 Answers
SOURCE: Broken Cigarette Lighter Splitter / Power Adapter
call whistler at 800-531-0004 to order a power cord.
Posted on Jun 13, 2008
timthorne911
  • 464 Answers
SOURCE: Cobra XRS 9950 Radar Detector not powering up
Contact Cobra, I have the same radar detector. It's still under the 1 year manufacturer's warranty. Get a new one, you have every right to do so. Cobra may even replace it. It wouldn't hurt to find out :) Here is their number 1-773-889-3087 Hope I helped you out!
Posted on Mar 19, 2009
  • 347 Answers
SOURCE: I have a Whistler 35
All Whistler's that are not battery powered run on 12 volts with the center tip postive. You can order a power cord by calling 800-531-0004 or whistler's online store at www.whistlergroup.com.
Posted on Feb 23, 2011
I have just purchased a new Vauxhall Corsa and my Navman 1CN320 will not fit in the cigarette lighter to keep it charged. Can you supply an adapter
Hi.
Here the adapter cable for your car lighter.
As far as I know the new Corsa has a standard cigarette lighter, the cable above should do the job. If the problem is different and you need more help, just let me know.
Regards.
Ginko
Oct 10, 2010 | Vacuums
My garmin nuvi 650 na keeps depleting its battery even though I just fully charge it on the computer. It also does not charge when I plug it in the cigarette lighter in the car. The screen turns dark...
well if you have the factory car charger. There is a fuse inside of it. This is indicated in the manual. But it could also be the cigarette lighter fuse in the car is blown. I would make sure the cigarette outlet has power. If the cigarette lighter has power and you have the factory power cable that has a fuse try this. f the unit will not charge in your vehicle, you might need to replace the fuse that is located at the tip of the vehicle adapter.
1. to change the fuse unscrew the black, round end piece on the vehicle power adapter and remove it. inspect the fuse to see if it is blown. If not end here.
2. if determined the fuse is blown remove the fuse (glass and silver cylinder), and replace it with a 1A fast blow fuse.
3.ensure that the silver tip is placed in the black end piece. screw on the black end piece
let me know how this works by following up with a comment and i can instruct you on where to go from here. Thanks.
Aug 26, 2010 | Computers & Internet
I have vectorlite 1.5 Million Candlepower light I want to know the ac charging adapter specification. We kind of lost track of particular adapter in recent moving :(. we appreciate your help....
Most of the Vector spotlights use a class 2 charger with an output of 12VDC 400ma with a positive (+) center connector, which are very common. I have several of these chargers from different manufacturers, and I use them interchangably on whichever spotlight I happen to plug them into.
One complication with my Vectors is they use a coaxial connector plug on the spotlight end that is a size N, which is being phased out and Radio Shack doesn'd even carry any more. If you hae a box of misc chargers, find a 12VDC one with a connector that fits your 1.5MCP light, and that is probably the one that came with your light.
Note that you can also charge your light with the cigarette lighter adapter cord that came with it. So if you can't find an AC transformer that fits but you have your cigarette lighter adapter cord, you can buy one of those cigarette lighter size gadgets that plugs into an AC outlet, and then plug your cigarette lighter cord into that.
Jun 28, 2010 | Vector 1 Million Rechargeable Spotlight
I need to know which fuse is for the cigarette
bye a LED test light and put one end on a good earth and use the other to probe the back of the fuses you should get power from both sides of the fuses if all fuses are good you will probably find the lighter socket is burnt out as this is fairly common
Jul 19, 2009 | Volkswagen Golf Cars & Trucks
At the end of the power cord for the radar detector the end screws off and there is a fuse for the radar detector itself. Check it....
If that isn't the problem post back for further help.
Thank you for choosing Fixya!
-dan
Mar 19, 2009 | ESD 6100 Radar Detector
Cigarette Lighter Pulled Out
there could be a wire in side the unit its self and that might have come dislodged
try it and let me know
Feb 28, 2009 | 1999 Toyota RAV4
Lighter plug
First if you still have the old "lighter plug" unscrew the ribbed end cap of the cigarette lighter adapter and check to see what size the fuse is. If you don’t have it anymore it originally took a 1amp fuse. Do Not use anything bigger then a 1amp fuse....You can pick them up at your local electronics store like RadioShack. In fact they will have a cigarette lighter adapter for you just remember to take in your Cobra ESD 6000 Radar Detector...I hope this helps...Let me know... cbinny1
Oct 20, 2008 | ESD 6000 Radar Detector
NO OUTLET TO PLUG INTO CAR
Most GPS would have a cigarette lighter adapter to charge the unit while in the car. If you vehicle has onle 1, then it would be needed to pullout the cigarette lighter and use that for the charger. If your unit does not have a cigarette lighter adapter/charger, then pls post back the brand/model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Garmin GPS
Vehicle Parts & Accessories Logo
50 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Jason
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
