Question about Compaq Presario F755US NoteBook AMD Turion 64 X2 TL-58
How to solve problem if print screen doesn't work in panasonic laptop?
    Habit-Forming:
  • 135 Answers
USE THIRD PARTY TOLLS FOR IT
LIKE LIGHTSHOT
SERACH FOR SCREENSHOT SOFTWARE IN GOOGLE
THEY ARE ADVANCED THEN PRINTSCREEN
Posted on May 08, 2014
Print screen on panasonic CF-53 toughbook
On any Panasonic Toughbook, when you press
"Shift" and "PrtSc" then this should capture whatever was
on the screen of your laptop.
This is usually a JPG picture. To see what it captured,
open the "Paint" program which is located under All Programs and Accessories.
When "Paint" is opened then click once in the blank portion of the screen, then click on "Edit" and then "Paste".
A shortcut is to use "CTRL" and "V"
You can now save the captured screen shot as an image.
That is it. Good Luck and Best Regads from:
Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Apr 10, 2014 | Panasonic Toughbook CF-51 Notebook
White spot on my laptop screen
Increase color depth for strange colors on your display.
If that doesn't work you probably have dead spots on your screen that no longer work. This means that your LCD assembly is no longer functioning and you will need to replace it.
Apr 04, 2012 | LG Computers & Internet
I turned on my labtop after repalcing the power inverter and the screen is still dark
Hi brylindo.
Try hooking your laptop to an external monitor...if the picture comes on then it is an lcd screen problem...if it doesn't come on then re-down load your drivers and see if that solves the problem...if it still doesn't work then you may have a problem with the laptop electronics.
Please take time to rate me
Sep 13, 2011 | Toshiba Satellite P105-S6197 Laptop
I have a CF-30 toughbook and my screen lights up for about 4 seconds and then goes dark everytime I open the the lid. I can see the screen is still on but not lit up, it will relight if I close the screen...
It could be loose wiring.
1. Take the screen bezel and LCD board off and reseat all the connections. In other words, unplug and plug it in again.
How to: CF-30 toughbook LCD replacement video
2. If that doesn't solve the problem, then you must replace the LCD inverter.
Best Regards,
Embraced Support
Fort Lauderdale Computer repair
Sep 05, 2011 | Panasonic Toughbook 30 Laptop
Laptop does not boot into operating system, it stops at LG screen and hangs
your OS must have crashed ... re install the OS your prb will be solved ..(if it doesn't work) your hard drive must have failed
Jun 21, 2011 | LG Computers & Internet
Problem with panasonic dp-2330. i can not print from my laptop. i have the usb cable from my laptop to the printer/copier. i downloaded print driver to my laptop. the laptop recognizes the printer by...
You must enable the USB in service mode F5-88
While holding function key, hold original size ledger key, while holding those two, press the 3 key. This gets you into service mode. Press 5 then the start key. Scroll to #88 and set the value to 2
Apr 27, 2011 | Panasonic WORKiO DP-2330 Copier
Print screen
After hitting the PrntScrn button, open wordpad .. right mouse click and select "paste". This will paste the content into wordpad and now you can print.
Mar 13, 2009 | Acer NSK8458AN Keyboard
Panasonic DP 1520P - wont print
Hi, I have solved my problem posted 5/2/08. Download the gdi driver from Panasonic website as I did above.
Install printer via Control panel, "Add printer" and browse to locate driver. If you do it automatic through the USB it will not work. Mine WORKS now!! Do check that the paper size is A4 also.
All the best...
Feb 05, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
Not printing on last copy
My guess is it?s probably the print head. These things are designed to print on single sheets so even though it?s probably well within specs it still doesn?t have enough force to push an image to the last page. Less likely but never the less a possibility this could also be caused by inconsistent paper in the two boxes. Continuous feed, multi-part forms in a box are made by several manufacturers and have different characteristics. -You might try flipping the box of forms from the printer that works to the one that doesn?t just to make sure it?s not the forms. When I used to use multipart forms we would place orders for several boxes of the same form and occasionally some would be from a different manufacturer. The paper looked the same but the characteristics were way different. By the way we tried to do four-part but could never print beyond three part forms. Our fix was that we decided we only needed one in-house copy. -If the problem doesn?t follow the paper then I would suspect the print head. Panasonic print heads are fairly easy to replace and fairly inexpensive so I would try changing it out. With a lot of use the print heads do wear out so even if this doesn?t solve this problem you?ll have a spare when your vertical characters start looking wavy?. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 14, 2007 | Panasonic KX-P2023 Matrix Printer
Compaq Presario F755US NoteBook AMD Turion 64 X2 TL-58 Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
