Question about IBM ThinkPad T43 Notebook
What causes a thermal sensing erro on ibm t43
My thinkpad ibm t43 only displays thermal sensing error and goes off
    Champion:
  • 207 Answers
A Thermal error on the T43 usually indicates a problem with overheating. This can be caused by many reasons:
1. Dirt build up on fan or fan louvres causing fan to turn slowly and not being able to cool the system properly.
2. Blocking of air inlets to the laptop. Do not use on your lap, or on soft surfaces such as blankets, bedsheets, etc.
If you feel a lot of heat from the air out of the laptop, then the system is over heating.
You can run fan diagnostics as follows:
1. Turn on the computer and check the air turbulence at the louver near the PC Card slot.
2. Run Diagnostics --> ThinkPad Devices
--> Fan.
Here is the T43 maintenance manual to see how to check and or replace the fan.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t6193.pdf
Posted on Sep 08, 2015
  • 43 Answers
SOURCE: ibm a31 0190 erroe
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/catalog.workflow:item.detail?GroupID=38&Code=02K6646&current-category-id=4364BD0F20B94413B5AD6E684D2848E9
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4PJRRG#72watt
I hope this helps.
Posted on Nov 05, 2008
tonyy168
  • 45 Answers
SOURCE: Thermal sensor error
Chcek www.thinkpad.com for a service manual.
Posted on Sep 15, 2009
bobfreengel
  • 37 Answers
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
  1. Right-click the My Computer icon and select Properties.
  2. Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters.
    Note: If the card has a exclamation mark over a yellow background, then this is an indication that the card is experiencing a problem. Go to Driver download step 5.
  1. Verify that the radio is enabled.
    It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
    Note: Follow the instructions provided to enable wireless card.
    • Most wireless cards will put an icon in the system tray (the line of icons in the lower right corner of your screen). Right click this icon and it may have a menu option to enable/turn on the wireless radio.
    • Some systems come with a Wireless Radio switch to disable the wireless radios. The wireless radio switch is usually located on the front side of the machine. If you are having difficulties with wireless connections, make sure the Wireless Radio switch is set in the On position.
  2. Check for association to an Access Point.
    If you double-click the previously mentioned system tray icon, the configuration utility of the wireless card will appear. This utility will be able to show the status of the wireless card, showing what channel the card is using and what signal strength is being received. It may be difficult to maintain a connection if signal strength is low due to either interference or distance. For example, interference can be caused by 2.4GHz cordless phones, other Access Points in the area, and physical structures such as load bearing walls or metal partitions.
    Note:
    The utility can be used to configure the wireless card settings, but if using Windows XP Zero Configuration or Access Connections, you will need to use those programs to actually configure the wireless card as they will overwrite the setting of the utility.
Posted on Oct 12, 2009
SOURCE: Thermal Sensing error
"Thermal sensor error" just means "Broken fan".
Posted on Mar 10, 2010
SOURCE: IBM thinkpad T43 wireless lan problem
I solve wifi problems on IBM Thinkpad T43 with this driver : http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18404&lang=eng
Posted on Jul 22, 2010
Location of thermal sensors on ibm t43
The heat sensor is mounted on the motherboard. The problem is most like with the fan being block by dirt or debris. See my answers here:
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=8&fml=0&brd=228&p=2&thid=24357750
May 08, 2014 | IBM ThinkPad R40 2681
How do i solve thermal sensing erro on ibm t43
See my answer here:
May 08, 2014 | IBM ThinkPad R30 2656 Notebook
Can't see my onscreen display after turning on F7 IBM T43 ThinkPad
set it to clone. it should give you identical displays. then try setting it to extended display. But make sure that your laptop display is primary display. That is why your external screen is displaying because it set on primary.
Jul 21, 2012 | IBM ThinkPad T43 Notebook
Thinkpad t43 will not start up after storage of 4 weeks
Take the Li-ion battery out, leave the machine hooked up to the AC power and try to start it. Li-ion batteries have a built in safety mode. When the battery falls to a predetermine level sensed by a chip in the battery pack, it sends a signal to the computer, "Do Not Start". Idoubt that the battery will now charge up as it has locked itself out to prevent overcharging and causing a fire.
Jan 11, 2011 | IBM ThinkPad T43 Notebook
<li><a
IBM Thinkpad X40 Battery cost EUR 79.99
Dec 23, 2010 | IBM ThinkPad T43 Notebook
Ask for Ibm Thinkpad T43 battery Price&#65311;
go to : Canada battery on-line shop,sell Laptop battery, Digital Camera Battery (DC ...... Welcome to buy ThinkPad T42, replacement laptop battery for IBM ThinkPad ...
https://www.linkme.com.au/groups/public
Jul 20, 2010 | IBM ThinkPad T42 Notebook
Sep 15, 2009 | IBM ThinkPad R40 2681
My ibm thinkpad t43 displayed a message "hard error D0014" on a small blue screen. when i shut it down by pressing the power button for a few seconds, it restarted. but the programs won't work.
This could be a problem, not sure if its a software related or if the hard drive is bad. If you can find a windows xp cd. Try and wipe out the hard drive and install windows xp on it. If it goes thru then you'll just need the drivers. If it errors out on you then you know its a problem with the hard drive and you'll need to replace it. If you get windows xp installed on it, let me know and I'll help you with the drivers.
Jun 04, 2009 | IBM ThinkPad T43 Notebook
Jan 11, 2009 | IBM ThinkPad R40 2681
Hard drive failure on IBM T43
I have a ThinkPad T43,
Now it's hard drive is broken so when i change the new hard drive Hitachi 160GB it display the message as below.
Could you help me to terminate this error message.
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
I try to update firmware of the harddrive but still appear the message the same.
Apr 23, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad T43 Notebook Logo
447 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
