Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
The LCD is out on my EPSON RX600 printer so I can't get cartridge carrier clear to change cartridge. I found solution several months ago but now have new computer so solution isn't in bookmarks. JPMenges
  • 23 Answers
See solution #4 above--That's what I do to change the ink.
Briefly;
Turn printer off.
Turn back on.
Press SETUP button.
Press DOWN arrow 4 times
Press OK button twice.
This should move the print head over to allow you to change the ink..
Posted on Sep 05, 2009
Epson RX600 service required. How can i reset the printer and get rid of the error message?
I just had this same error message pop up on my RX600 yesterday. There is a utility that you can d/l from the Epson website to reset the counter at the link below.
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
The reason the service message pops up is that it is telling you that the waste ink pads are near the end of their service life and probably saturated with ink. You should still clean the waste ink pads or ink will eventually run out the bottom of your printer and create a big mess. If you do a Google search for something like "rx600 waste ink pads" there are some how-to discussions on doing this yourself. I'm going to clean mine later today.
They say it's not hard to do and you don't have to disassemble your printer, just use a toothpick or modified paperclip to remove the pads after you park the cartridges in their "replace ink cartridge" position and unplug the printer. A more detailed procedure can be found with the Google search.
Aug 25, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600: Banging noise when turning on printer
Ok I think this is the cartridge carrier doing the banging I have had this on 2 or 3 epsons that I oncwe owned. If you clean those rails that the cartridge container slides on the banging should cease. Dont need to oil them just a damp cloth will do it. You can try sewing machine oil later. only a very small drop ( smidgen) on a cloth to wipe both rails.
Please rate our help and keep this site alive
Aug 16, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Older Epson stylus photo rx600 printing orange
Cleaning cycle a few times. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Jun 28, 2009 | Epson Stylus 1400 InkJet Photo Printer
Error Message
Please check connecting cables with PC.
Unplug printer form AC outlet for couple of minutes and replug back in and check.
Jan 30, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Rx600
Here is a link to the Epson printer RX600 support page which has downloads of latest printer drivers for your unit.
Did you remove any type of protective material that may be on the cartridge before installation?
Apr 26, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Photo RX600 error messages
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Feb 10, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Can't seem to print in black only.
Are ya sure it isn't only preventing scanning direct to printer output? Is it also disallowing scanning to file? Epson printers can´t operate if one of the cartridges is empty. There is no workaround for that. Epson printers actually use a LITTLE ink from ALL the color carts, even when you select "black only" in the driver. They do this to help keep the nozzles from clogging in the case of users who mostly print in black. Nobody [besides perhaps Epson] ever claimed Epson printers were the most efficient or environmentally-friendly ones in the world. for quite a while now Epson uses piezoelectric printheads, as opposed to the thermal heads used on most other printers. The enemy of piezo heads is air bubbles. They candamage the costly head, and that's why you cannot continue to use the printer if ANY individual cartridge runs out of ink. In fact, Epson designed its cartridges to signal "empty" when there's still around 15% (higher by some estimates) ink left! That's to make certain you can't run the cart completely dry and thereby introduce air into the head. If you don't believe that, carefully open up a spent cartridge over a sink, slice open the plastic film covering the various ink channels and rinse it out -- repeatedly push in the spring loaded outlet valve as well. There's so much ink left, it will take quite a while before the water begins to clear! It's incredibly wasteful and annoying, but it actually saves money in the long run, because it's even MORE wasteful to run tons of cleaning cycles just to purge the head once you've gotten air in the system. Aftermarket carts and ink can save lots of money, but they're a crap shoot. Fed up with OEM price gouging and scare tactics, I decided to try a clear-cartridge refill kit for my R200. The RX600 uses the same kit: http://www.inkjetcarts.us/servlet/Detail?no=8 Good Luck!
May 04, 2006 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
338 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
