Question about Beko Fridge/freezer Thermostat Genuine 9002752885
How i know if the fan fault ?
How i know if the thermostat fault?the the bottom room is not cooler built ice.
  • 641 Answers
Hi Hytham,
You may want to check this video. Hope it helps.
Posted on May 08, 2014
What causes the top 2/3 of the evaporator coils to get frozen over, but leaves the bottom 1/3 clear of any frost?
no the defrost thermostat only need be checked at cold temp and at room or reg temp it should not show any continuity have u checks ur heating element out as well and defrost timer ? I still suspect a faulty thermistor the freezer has more than one thermistor?
Mar 31, 2016 | Refrigerators
The freezer not working correctly
The defrost element has faulted, it is relatively easy job, the element is the large metal piece on the bottom of the freezer coil. Disconnect the wires and undo the securing straps fit the new one and secure etc. may also pay to replace the defrost termination sensor. This can be ignored but it will periodically ice up and need defrosting. Last point, sometimes the drain pan gets blocked and the ice buildup begins( you find less ice than a normal defrost fault, you did say not excessive) in this case only the drain needs unblocking and everything will be fine. Can sometimes pay to wait and see if it happens again. Provided you cleared the drip pan drain completely when defrosting.
Jul 10, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Nov 04, 2009 | GE ZDW24A Wine Cooler
WHY THE FAN IN MY WALK-IN COOLER GETS FROZEN
How to Replace walk in cooler defrost timer
Jun 30, 2009 | Refrigerators
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Fan blower coleman electric cooler
The fan should blow air into the heat sink. The warm air exits the heat sink at both ends. (It might work the other way, haven't tried it.)
When you have ice in your cooler, you know the thermo-electric element is working well--it's below freezing!
Ice builds up because there is water in the cooler. For example, in humid weather, you open the cooler, some humid air gets in, and the cooler temperature condenses the water. You have to empty this water, either by tipping the cooler, or using a sponge.
You can easily defrost the cooler by unplugging it for an hour or so. You know it's time to defrost when you hear the fan blades making a racket because they're hitting something--a thick buildup of ice.
Aug 10, 2008 | Coleman Electric Cooler 40 Beverage Cooler
Water not running on Samsung RS21DCNS - why?
Water tank in bottom of fridge can freeze up if thermostat gives up. First water will stop coming out, then ice starts building up, then fan starts making noise as it brushes against ice, then fan fails, then fridge warms up  ---- all a well know scenario with this fridge. I wonder if this is the problem you have ?
Apparently Samsung are now recognizing this as a design fault and extending unit guarantee. Ring them on: 0870 726 7864  and see what happens...
Jul 07, 2008 | Samsung Refrigerators
Fridge not running well
Not sure of what type of fridge you are refering to.. However you can try a few obvious things. Try turning the thermostat to a lower number (warmer setting) to see if that makes a difference. If you have an ice build up starting to form on the fridge plate or only a partially cold plate then you could have either a loss of refrigerant or compressor fault. Is the compressor noisey in comparisson to its normal noise. Is there heat being produced all over the condenser (black finned section on back of cabinet or underneath cabinet)..If not possible gas leak. Hope this is of some help.
Sep 07, 2007 | Haier BC112G Wine Cooler
Beko Fridge/freezer Thermostat Genuine 9002752885 Logo
52 people viewed this question
Top Beko Refrigerators Experts
Electro Med Services...
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
