Question about IBM ThinkPad R30 2656 Notebook
How do i solve thermal sensing erro on ibm t43
The laptop comes on and display thermal sensing error and goes off
    Champion:
  • 207 Answers
See my answer here:
http://www.fixya.com/answer/answerpageslideview.aspx?ctg=8&fml=0&brd=228&p=2&thid=24357750
Posted on Sep 08, 2015
5 Suggested Answers
  • 43 Answers
SOURCE: ibm a31 0190 erroe
Error 0190 means you need to charge your battery. Either your battery is not charging properlty or your charger is not working anymore. If the computer works while plugged in and gives no error then it would be the battery that needs replacing. If the battery is a few years old then you may want to order a replacement. The Thinkpad A31 uses the ThinkPad Ultrabay 2000 Li-Ion Battery. You can purchase a replacement battery from this website:
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/catalog.workflow:item.detail?GroupID=38&Code=02K6646&current-category-id=4364BD0F20B94413B5AD6E684D2848E9
If the laptop doesn't work while plugged in and you dont get any lights on the battery or power indicator on the front of the laptop then you may need a replacement. Depending on which region you are in you will need a different A/C adapter. You can find a list of different A/C adapters here.The A31 uses the 72 watt power adapters on this page:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4PJRRG#72watt
I hope this helps.
Posted on Nov 05, 2008
SOURCE: hard drive failure on IBM T43
I have a ThinkPad T43,
Now it's hard drive is broken so when i change the new hard drive Hitachi 160GB it display the message as below.
Could you help me to terminate this error message.
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
I try to update firmware of the harddrive but still appear the message the same.
Posted on Dec 26, 2008
benwabnick
  • 2404 Answers
SOURCE: my ibm thinkpad t43 displayed a message "hard error d0014"
This could be a problem, not sure if its a software related or if the hard drive is bad. If you can find a windows xp cd. Try and wipe out the hard drive and install windows xp on it. If it goes thru then you'll just need the drivers. If it errors out on you then you know its a problem with the hard drive and you'll need to replace it. If you get windows xp installed on it, let me know and I'll help you with the drivers.
Posted on Jun 04, 2009
caroldon
  • 17129 Answers
SOURCE: IBM R51 laptop when start the laptop it canot boot
Possible that the cooling fans to the Processor is clogged and so there is heating on the processor going beyond the set limit thereby triggering the thermister to warn and shut down.
This normally happens when the laptop is make work on dusty surroundings/ tops or matresses which can pull up fibres to clog the vent.
remove the fan assembly and clean the section using a air jet and brush , then reset.
Posted on Jul 05, 2011
Location of thermal sensors on ibm t43
The heat sensor is mounted on the motherboard. The problem is most like with the fan being block by dirt or debris. See my answers here:
May 08, 2014 | IBM ThinkPad R40 2681
What causes a thermal sensing erro on ibm t43
A Thermal error on the T43 usually indicates a problem with overheating. This can be caused by many reasons:
1. Dirt build up on fan or fan louvres causing fan to turn slowly and not being able to cool the system properly.
2. Blocking of air inlets to the laptop. Do not use on your lap, or on soft surfaces such as blankets, bedsheets, etc.
If you feel a lot of heat from the air out of the laptop, then the system is over heating.
You can run fan diagnostics as follows:
1. Turn on the computer and check the air turbulence at the louver near the PC Card slot.
2. Run Diagnostics --> ThinkPad Devices
--> Fan.
Here is the T43 maintenance manual to see how to check and or replace the fan.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t6193.pdf
May 08, 2014 | IBM ThinkPad T43 Notebook
Can't see my onscreen display after turning on F7 IBM T43 ThinkPad
set it to clone. it should give you identical displays. then try setting it to extended display. But make sure that your laptop display is primary display. That is why your external screen is displaying because it set on primary.
Jul 21, 2012 | IBM ThinkPad T43 Notebook
Thermal sensing error on ibm thinkpad r40
I think it isn't much importance for the ibm thinkpad t40, anyway it is not easy matter to solve.
May 14, 2011 | Computers & Internet
My ibm thinkpad t43 displayed a message "hard error D0014" on a small blue screen. when i shut it down by pressing the power button for a few seconds, it restarted. but the programs won't work.
Jun 04, 2009 | IBM ThinkPad T43 Notebook
Thermal Sensing error
"Thermal sensor error" just means "Broken fan".
Jan 11, 2009 | IBM ThinkPad R40 2681
When I tried to switch on ny laptop t43 it is failing to boot,
Is there any way I can take a remote session on your laptop ? .. This way I can look into the problem andb can find the appropriate solution.
regards
Nitin
Nov 29, 2008 | IBM ThinkPad T43 Notebook
Hard drive failure on IBM T43
Apr 23, 2008 | IBM ThinkPad T43 Notebook
T43P LCD keeps going dark
I think you are having problem with backlight. The concept of laptop is that if there is problem with backlight then it will try to shut it down(shut the light down).If you restart your laptop ,that mean you turn the light on again...after that if its blink or something wrong then again your system will try to shut it down to prevent other part get spoil.
What you have to do is..
1.problem from backlight replace backlight
2.problem from inverter replace inverter
3.problem from motherchip...repair motherboard.
Byebye,takecare
Apr 22, 2008 | IBM ThinkPad T43 Notebook
IBM ThinkPad R30 2656 Notebook Logo
87 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
