Question about GE Energy Star WCVH6260F Front Load Washer
Wcvh6800j1mr remove pump
    Genius:
  • 1,554 Answers
Remove power
remove 3screws spline on front bottom panel
theres ur pump
Posted on May 19, 2014
How long does it take to replace a water pump on Pontiac Aztec?
It takes near to 1.5 hours to replace the water pump on Pontiac Aztec. The procedure to replace the water pump is as follows:--- Water Pump Replacement ---------
Removal Procedure :
  1. Drain the cooling system until the coolant is below the level of the water pump.
  2. Remove the drive belt guard.
  3. Loosen the water pump pulley bolts.
  4. Remove the drive belt.
  1. Remove the water pump pulley bolts.
  2. Remove the water pump pulley.
  1. Remove the water pump bolts.
  2. Remove the water pump.
  3. Remove the water pump gasket.
  4. Clean the water pump mating surfaces
Installation Procedure
  1. Install the water pump gasket.
  2. Install the water pump. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley. Loosely install the mounting bolts.
  2. Install the drive belt.
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 inch lbs.) .
  1. Install the drive belt guard.
  2. Fill the cooling system.
  3. Inspect the cooling system for leaks.
  4. That's it.
Nov 18, 2010 | 2001 Pontiac Aztek
Have a GE Model WCVH6800J1MR that doesn't fill with water. It appears to start and spin when the soap would go in, but no water. Checked water supply is fine. Checked for kinked hoses they are also...
Cool thing about these new computer controlled appliances is that they diagnose themselves. Easiest way to find issues is to run a diagnostic test: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Post back once you have the codes and we'll see about next steps.
In addition to t02, you should definitely do "t08" and "t09" tests to check the hot/cold water valves. chris_in_ma_7.jpg
Oct 13, 2010 | General Electric WCVH6800J Front Load...
How do you chace a oil pump on a honda goldwing 1200 cc
There are two oil pumps; the Main Oil Pump and the Scavenger Oil Pump. I will list the procedure for both pumps.
Main Oil Pump
1) Put the bike up on the center stand
2) Remove the engine front cover
3) Remove the collar and O-ring seals from the oil pump cover
4) Remove the bolts and Phillips screws holding the oil pump cover on and remove the cover
5) Remove the dowel pins from the oil pump body
6) Remove the inner and outer rotors
7) Remove the drive pin and washer from the drive shaft and remove the oil pump body from the cylinder block - The drive shaft will remain in the cylinder block. (Do not lose the locating dowel in the cylinder block).
8) Clean all parts before replacing the new oil pump
9) Install in reverse order
NOTE: If it is necessary to remove the oil pump drive shaft, the cylinder block will have to be disassembled. Also it is a good idea to coat all parts with oil prior to installing the new pump.
Scavenger Oil Pump
1) Remove the engine from the frame
2) Remove the engine read cover
3) Remove the clutch outer housing
4) Remove the bolts holding the oil pump to the cylinder block and remove the pump
NOTE: Both of these pumps can be rebuilt with fairly easy and it's considerably less expensive to do so.
Sep 21, 2010 | 1984 Honda GL 1200 Aspencade Gold Wing
Cant find were to put powersteering fluid
Power Steering Pump Removal & Installation 3.8L Engine To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Place a drain pan under the vehicle.
  3. Remove the accessory drive belt from the power steering pump pulley.
  4. Raise and safely support the vehicle.
  5. Remove the right front tire and wheel assembly.
  6. Remove the hoses from the power steering pump.
  7. Remove the mounting bolts and the power steering pump from the engine.
  8. Remove the reservoir and pulley from the pump if necessary.
To Install:
Power steering pump removal/installation (3.8L engine) gm-08-38-480.gif
  1. If removed, install the power steering pump reservoir and pulley on the power steering pump.
  2. Position the power steering pump to the engine and install the mounting bolts. Tighten the bolts to 25 lb ft (34 Nm).
  3. Install the pressure and return hoses to the pump.
  4. Install the right front tire and wheel assembly.
  5. Lower the vehicle.
  6. Install the accessory drive belt.
  7. Fill and bleed the power steering system.
  8. Inspect the system for leaks.
  9. Remove the drain pan from under the power steering pump area.
3.4L Engine To Remove:
  1. Place a drain pan under the power steering pump.
  2. Remove the coolant reservoir.
  3. Remove the pulley from the power steering pump.
  4. Remove the wiring harness near the power steering pump and place it out of the way.
  5. Disconnect the fluid hoses from the power steering pump.
  6. Remove the mounting bolts from the power steering pump and remove the pump.
To Install:
Power steering pump removal/installation (3.4L engine) 88008g71.gif
  1. Position the power steering pump assembly to the engine and install the mounting bolts. Tighten the mounting bolts to 25 lb ft (34 Nm).
  2. Install the wiring harness in its original position.
  3. Install the pulley on the power steering pump.
  4. Install the coolant reservoir.
  5. Fill and bleed the power steering system.
  6. Inspect the system for leaks.
  7. Remove the drain pan from under the power steering pump.
Sep 18, 2010 | 2000 Chevrolet Impala
Power steering pump, broken, how to replace
Power Steering Pump - REMOVAL & INSTALLATION
3.0L OHV (2 valve) Engine
(see Figures 1 and 2)
Fig. 1: Power steering system-3.0L OHV (2-valve)
Fig. 2: A few special tools are required to remove and install the pulley on the power steering pump
  1. Disconnect the negative battery cable.
  2. Remove the accessory drive belt.
  3. Remove the alternator.
  4. Drain and remove the radiator coolant recovery reservoir.
  5. Position a drain pan under the power steering pump underneath the vehicle. Disconnect the hydraulic pressure and return lines and allow to drain.
  6. Remove the idler pulley from the power steering pump support.
  7. Remove the bracket mounting bolt located under the belt tensioner mounting.
  8. Remove 2 retaining nuts from the bracket mounting studs. Remove both mounting studs, and pull off the power steering pump support with the pump attached.
  9. Clamp the pump support bracket in a suitable vise.
  10. Remove the power steering pump pulley from the pump shaft using Pump Pulley Remover T69L-10300-B, or equivalent. Remove the 3 bolts retaining the power steering pump to the power steering pump support and remove the power steering pump.
To install:
  1. Install the power steering pump to the power steering pump support.
  2. Install the power steering pump pulley using Steering Pump Pulley Replacer T65P-3A733-C, or equivalent; the pulley face must be flush within 0.010 inch (0.25mm) of the pump shaft.
  3. Install the power steering pump/pump support and torque nuts/bolt to 17-24 ft. lbs. (23-32 Nm).
  4. Complete the installation by reversing the removal procedure.
  5. Fill the power steering reservoir with power steering fluid.
  6. Connect the negative battery cable.
  7. Run the engine and check for leaks and proper operation. Bleed the power steering system if needed.
Hope this helps.
Sep 06, 2010 | 1996 Ford Taurus
Change oil pump from engine
THE 3.0 ENGINE YOU HAVE TO REMOVE THE UPPER INTAKE MANIFOLD .REMOVE VALVE COVERS REMOVE ACESSORY DRIVE BELT.REMOVE THE POWER STEERING PUMP.REMOVE ALTERNATOR REMOVE WATER PUMP .REMOVE AC COMPRESSOR AND BRACKET .REMOVE CRANKSHAFT PULLEY REMOVE OIL PAN REMOVE OIL PUMP SCREEN AND THE TUBE REMOVE FRONT COVER REMOVE TIMING CHAINS REMOVE CRANKSHAFT TIMING GEARS REMOVE OIL PUMP.WHEN INSTALLING NEW OIL PUMP AND OIL PUMP SCREEN AND TUBE TORQUE BOTH 89 INCH POUNDS. THE 3.9 ENGINE REMOVE THE CRANKSHAFT PULLEY REMOVE FRONT COVER REMOVE THE PRIMARY TIMING CHAINS REMOVE OIL PUMP MOUNTING BOLTS REMOVE OIL PUMP.INSTALLING NEW OIL PUMP TORQUE BOLTS TO 53 INCH POUNDS. WARNING YOU NEED A REPAIR MANUAL IN ORDER TO RELINE TIMING MARKS ON CAMSHAFTS AND CRANKSHAFT.
Apr 22, 2010 | 1997 Lincoln Continental
How do you replace a water pump in an aztec?
Notes Water Pump Replacement
Removal Procedure
Jun 17, 2009 | 2001 Pontiac Aztek
How Do i replace Water Pump on 98 Chevy Metro
  1. Remove the negative battery cable.
  2. Drain the engine cooling system.
  3. Remove the air cleaner assembly.
  4. Remove the A/C compressor suction pipe bracket (if equipped).
  5. Loosen four water pump pulley bolts. Do not remove the bolts.
  6. Raise the vehicle. Support the vehicle. Remove the right lower splash shield.
  7. Remove the right lower splash shield.
  8. Remove the A/C compressor drive belt (if so equipped) by releasing the tensioner pulley and removing the belt from the crankshaft and compressor pulleys.
  9. Loosen the generator adjusting bolt (1), pivot the generator and remove the water pump/generator drive belt.
  10. Remove the crankshaft pulley.
  11. Remove the water pump pulley (four bolts).
  12. Remove the timing belt.
  13. Remove the oil level indicator (dipstick) guide tube.
  14. Remove the upper generator adjusting bracket from the water pump (one bolt).
    1. Remove the rubber seals from the water pump.
    2. Remove the water pump mounting bolts and nuts.
    3. Remove the water pump and gasket from the vehicle.
    4. Clean the water pump and the gasket mating surfaces.
    5. Install the water pump.
    6. Secure the water pump with mounting nuts and bolts. Tighten Tighten the water pump mounting nuts and bolts to 13 Nm (115 ft. lbs.).
    7. Install new rubber seals (1) to the water pump (2).
    8. Install the upper generator adjusting bracket to the water pump (one bolt).
        • Tighten the upper generator mounting bracket bolt to 23 Nm (17 ft. lbs.).
      1. Install the oil level indicator (dipstick) guide tube.
      2. Install the timing belt.
      3. Install the water pump pulley.
      4. Finger-tighten the four bolts.
      5. Install the crankshaft pulley.
      6. Install the water pump/generator drive belt to the crankshaft, water pump and generator pulleys.
Nov 20, 2008 | 1998 Chevrolet Metro
GE Energy Star WCVH6260F Front Load Washer Logo
22 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
