Question about Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh)
Engine runs good for 30 minutes then starts surging and when stopped it dies 1988 chevy 1/2 ton truck fuel injection
    Genius:
  • 1,198 Answers
It could be something as simple as a faulty gas cap, but you will have to do some detective work. Be prepared for the next time. Have a can of starting fluid and an old time induction timing light. You will have to have someone to crank the starter for you. When it dies, quickly hook up the timing light to the spark wire and spray some starting fluid into the air intake. Find the intake ahead of time, they aren't always obvious. Same for the spark wire, I would try for the coil wire if this unit has a distributor, you will get a better sign. You are only looking for spark, not timing. If you don't see spark, now you know what to start checking. Coil, and all the other spark stuff. If you get spark and it runs on the starting fluid, your fuel system is failing. Start with the fuel pump, filter, and any safety switches. My Ford had a 'collision' switch that would shut off the fuel pump. At your trucks age, any electronic part can be breaking down. Fuel relays are my first suspect. Never buy off brand, always OEM.
If your truck has a computer, have the codes checked.
Posted on May 08, 2014
IT WILL STaRT , RUN FOR 1 MINute AND SHUT OFF BUT WAS rUNNING WITH COVER OFF BUT NOW HAS STOPPED THAT IT WILL RUN FOR 20 SEcONDS AND SHUT OFF
What would cause 1995 Chevy blazer to run for 20 minutes ...
answers.angieslist.com > Auto > Auto Repair & Service
Mar 30, 2014 - For example, can you start the car cold, it will warm for 20 minutes, and shut ... While not a car, my Motorcycle (also fuel injected) would run for a little bit and shut off. The issue ... Answered 1 year ago by WoWHomeSolutions.
Car starts and it shuts off/loses power - CarGurus
www.cargurus.com > Questions > Audi > A4
CarGurusJun 20, 2013 - Car starts and it shuts off/loses power - I have a 2003 Audi A4 Turbo.93K on it. ... \n check out these few options 1. loose or faulty electrical connections at, .... After drying it for a few minutes and cleaning with a dry cotton cloth, I have ... you can't fill your car while its running the gas tank is a vacum while its ...
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Car was running fine, and then engine stops. ... 1 out of 1 people think this is helpful. ... my car will start run for a second an shut off . ... under load, dies,starts 15 minutes later, runs fine then stumbles and dies again 3 answers.
Chevrolet Silverado 1500 Questions - Engine Shutting off ...
www.cargurus.com > Questions > Chevrolet > Silverado 1500
CarGurusMay 20, 2015 - Engine Shutting off after about 10-20 seconds on 2004 Silverado ...When the engine is hot, two things occur: (1) thermal effect on .... my 2000 chevy silverado just randomly die then it will start back up idle .... It will run fine for 15minutes. ... run down behind or beside the powersteering pump, that the car will ...
Jan 06, 2016 | Cars & Trucks
1988 Chevy V8 5.7L 350 4bbl . My vin starts with 2GBJG31M9J4 . it is a RV jamboree with the chevy 1 ton heavy duty emission. does anyone know where I can find a vacuum diagram?
Vacuum Diagrams - AutoZone
www.autozone.com/repairinfo/.../repairGuideContent.jsp?page...
AutoZoneGM Chevy Mid-Size Cars 1964-1988 Repair Guide ... Fig. Fig. 4: 1971 V8 enginevacuum hoses ... Fig. Fig. 12: 1976 350 V8 engine-4bbl with EFE and AIR injection systems .... Fig. Fig. 52: 1980 5.7L V8 engine-automatic transmission federal. images for 1988 Chevy V8 5.7L 350 4bbl vacuum ...
Nov 23, 2015 | Cars & Trucks
1987 chevy with Throttle Body... You literally have to put it to the floor to get it to start, then it'll run nice for a while thinking it'll run take it for a drive and it will shortly die on
Check all fuel lines for leaks, make sure it doesn't have bad gas in it. Listen for fuel pump when key is turned on. Change fuel filter. See if that's helps.
Dec 16, 2012 | 1988 Chevrolet K3500
My 1988 Chevy s-10 engine runs fine for 1 minute, then sputters until it stops 1 minute later. Why?
first start with your timing. if not th problem you need to check for a vacuum leaks. make sure all hose have no leaks and are connected.check wiring harness connection to distributor, coil, or alternator for being damaged or loose. last is to check if you have a good fuel flow to the engine. It could be the fuel pump or just a bad fuel filter
Nov 30, 2010 | 1988 Chevrolet S-10
My 88 chevy 2500 3/4 ton runs, but when given gas
check your fuel filter under the left side of the vehicle on the frame. if this proves to good, your next step might be checking your catalytic convertor. have you checked all of your vacuum lines? one thing you can do is have your friend inside to start the vehicle and while it is idling and the air cleaner is off, look inside at the fuel injector and you throttle it and see if the injector is spraying fuel.
Nov 09, 2009 | 1988 Chevrolet C2500
No power to left side fuel tank
Check the ground wire for good contact.
Apr 11, 2009 | 1988 Chevrolet C3500
I have a 1988 Chevy C3500 1 ton PU. Engine runs great at idle and acceleration but when cruising it runs rough or surges.
if the truck has a locking converter goin bad it will surge at steady speeds such as 55 mph the converter will lock and unlock causing you to feel an surging
Mar 07, 2009 | 1988 Chevrolet C3500
Engine cranks excessively before engine starts,even after warmed
Check your EGR valve make sure that is working properly, if it is then go to the fuel pump, just a cheaper fix to go after the EGR then the fuel pump
Feb 09, 2009 | 1988 Chevrolet K1500
How to change 1988 dodge b150 1/2 ton 5.2L throttlebody fuel injection to multiport fuel injection
you should swap complete engines and ecus i have seen this set up installed in a 1938 dodge truck so yes it can be done
Oct 17, 2008 | 1988 Dodge B150
Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh) Logo
79 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
