Question about Garden
Bobcat skidsteer S150 head lights not working . Need to find fuses .
    Champion:
    Habit-Forming:
  • 210 Answers
I am guessing there is a short in the wiring. To be careful, you can also check the spark plug for the head lights. I am not sure where the spark plugs are located in that model though.
Elisa Jed ' http://www.aussieplanthire.com.au/Our-Company
Posted on May 15, 2014
Bobcat Creep, how do I stop it
as the equipment ages so do its springs or detents , some models of skidsteers have a "zero" pressure ballance adjusting bolt on top of the hydrostat drive housing , and some of them don't , they got them dreaded operator interface modules ,you cant do nuttin with !! anyways look real carefull at base of handles mounting you might see a spring or two that you can change for about five bucks that'll get you going
Apr 19, 2015 | Bobcat Garden
How do I reverse blower motor on bobcat sb 240 snow blower attachment
if your skid steer doesnt have a reversing remote valve (contact bobcat some models can be retofitted in field), then the only way to reverse is to unhook the hoses from and to the drive motor and unscrew lines to put hoses reverse direction , becarefull there maybe some residual oil pressure still there if you really need to do this after reconnection to skidsteer and remote is activated then blower will run backwards
Feb 21, 2015 | Garden
Bobcat 641 skidsteer hydraulic problems.
That's one of the first things that came to mind as I was reading through your post; that the system was air-bound. Are there bleeder valves on the system?
In any event here is a website where you can buy the service manual for your skidsteer; https://mypowermanual.com/shop/bobcat/bobcat-641-642-643-skid-steer-loader-service-manual-download-6566135-10-86/
Feb 20, 2015 | Bobcat Garden
Is there an easy way to change the alternator on my 2000 751 bobcat skidsteer? I am having a hard time accessing it and I need to replace the alternator bracket.
about the easyest way is to have very long arms or you'll have to remove the radiator just like the rest of us short'tys
Jan 01, 2015 | Bobcat Garden
How do I change the alternator on a Bobcat 773 skidsteer loader
Why do you suspect the alternator? Have you checked the output? Put a meter across the battery terminals when running at fast idle and it should be 14.5volts and no less than 13. Poor cold start is usually the heater plugs/ failed heater plug timer or poor battery strength. Start at the beginning and see if the alternator is working OK, then work through the rest. Test the heater plug supply by putting the meter from the plug supply cable to ground when the switch is in cold start position. Should have 12v at least. Make sure both battery cables have good clean connections at both ends to chassis or starter. Most cold start problems can be fixed by careful maintenance and basic systems checks.
Nov 15, 2014 | Bobcat 773
How do I fix an service code 83-03 on a Bobcat S150
i have found you a service manual which might help you
http://igor.chudov.com/manuals/Bobcat-S250-Manual.pdf
Nov 10, 2014 | Garden
Fuse panel on s300 bobcat skidsteer
The fuse panel is that black metal box between your legs if you are sitting in the unit. It is held in by two 1/2" bolts
Mar 13, 2013 | Toys
My 1993 compact bobcat skidsteer won't start, it just stopped running and won't start, I have tried starting fluid and still nothing?
Could be engine speed sensor. All fuses need to be checked. Any smoke when cranking? Any fault codes? A bad fuel solenoid could cause no start if fuel is good.
Sep 09, 2012 | RTO Construction Bobcat by Woody Click
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
