Question about HP Deskjet F2480 All-in-One Printer
How to order power cord for HP f2840 all in one printer
Cord damaged needs replaced
  • 3 Answers
Order one from Factory Direct.
Great store.
Posted on May 08, 2014
leroyal
  • 2120 Answers
SOURCE: HP Psc 1410v All-in-One Printer Power cord And adapter
Check www.hp.com partsurfer or eBay
Posted on Jan 09, 2009
  • 149 Answers
SOURCE: power cord is damaged and needs replaced
i am not in any way offiliated with the following website but it was the first one to come up in google
http://www.sparepartswarehouse.com/HP,Printer,Part,09572119.aspx
bearing in mind the part is quite cheap there must be lots of places you can obtain a spare/replacement power supply...and if they are sold seperately the clerk that gave you the advice about not being able to replace just the power cord must have been having a bad day/year/lifetime
Posted on Jan 26, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Need replacement power cord for HP psc 1210 printer.
This printer utilizes a power cord identicle to one used on a PC.
Posted on Sep 30, 2009
Testimonial: "This is great! I've spent a week searching for an answer and getting nowhere. Here I get an answer within an hour. Unbelievable!"
  • 53 Answers
SOURCE: Need a Power Cord for 2575 Printer.
Part number of the Power cord: 8120-6260
You can purchase it from the below webpage:
http://h20141.www2.hp.com/hpparts/Search_Results.aspx?mscssid=F8C75F60E28A414E8E9B83CFE8B4ED4E&SearchIn=PartNumber&SearchPN=8120-6260
Posted on Oct 02, 2009
Coastsider
  • 331 Answers
SOURCE: I need a power cord for my hp 750 printer
HP.com is great place to start... go to the support area and start a chat or email support with your model.. They may be able to assist you... If not then try http://www.sparepartswarehouse.com
Posted on Apr 12, 2010
Error code 02.01.10
02.1:10 error indicates that the encoder is not working.
Try the following:
Switch power off and unplug the power cord. Reconnect and turn the power back on.
Check that the trailing cable is not damaged (wide cable that goes from the main PCA to the Carriage PCA)
Replace parts in this order: Trailing Cable, Carriage PCA, Main PCA.
Aug 14, 2013 | HP Designjet T610 InkJet Printer
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
ERROR 08:11 HP DesignJet Z2100 InkJet Photo Printer
08:11 error = no communication between formatter and front panel
Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
If the error persists, you are going to need a tech to do the following:-
Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel.Check that the connections between the Formatter and the Main PCA are not damaged and are correctly connected.
If the System Error continues, replace the Formatter
If the System Error continues, replace the Main PCA
If the System Error continues, replace the Front Panel
Nov 07, 2011 | HP DesignJet Z2100 InkJet Photo Printer
I need a power cord and software drivers for my unit.
Click here for information on ordering replacement parts from HP. However, I'd suggest trying Ebay first.
Drivers for your printer are available here.
I am an HP employee. I do not represent HP on this site.
May 27, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Power interrruption over the weekend. HP 4200 won't power on. Outlet, cord, fax and copy machine all work. Is there a reset on this machine?
Sounds like the power supply was damaged. You need a new Low Voltage Power Supply . Local HP repair center can diagnose and repair for you. Kind of tricky to replace as there are many parts to replace and multiple cables routing through different areas of the printer. Easy fix for an experienced technician. Repairing yourself could cause more damage and end up costing more.
Dec 07, 2009 | HP LaserJet 4200 Printer
I've lost the plug or cord for my photosmart.
You may contact HP customer service and verify HP center in your location. 800-752-0900
Jun 30, 2009 | HP Photosmart 2575 All-In-One InkJet...
Can not find power cord anywhere for my printer
part number for power cord u want to order just select ur choice and order it online or call hp in U.S 800-BUY-MYHP or for others find contact here www.hp.com
Power Cord (Europe) 8120-6262 Power Cord (Denmark) 8120-8881 Power Cord (Israel) 8120-8883 Power Cord (South Africa) 8120-8886 Power Cord (Switzerland) 8120-8885 Power Cord (United Kingdom) 8120-8882
Mar 30, 2009 | HP Officejet 5610 All-In-One InkJet...
Power cord is damaged and needs replaced
Jan 07, 2009 | HP Deskjet F340 All-In-One Printer
Hp photosmart c4580 won't print
Your problem indicates that your printer is not getting the power supply .
  • Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
  • If the power cord is not damaged, plug the power cord into a different electrical outlet without using a surge protector. The product power light should turn on.
  • If the product power light does not turn on, the power cord should be replaced.
Dec 09, 2008 | Office Equipment & Supplies
Printer takes a long time to start
Hi! Sorry to hear of this issue! There are a few steps you can do to diagnose the issue. If these steps do not work, let me know and I can suggest other steps or which part you may need to order. I can be emailed directly at: bosscomputers@comcast.net or http://bosscomputers.org Follow the steps below to ensure power is properly supplied to the printer: Check the power module part number against the part number listed in the User?s Guide to ensure the proper power adapter is being used. Disconnect the power cord from the wall outlet. Disconnect the printer data cable from the printer. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning. If the power cord does not work on the other printer, it is defective. Replace the power cord. If the power cord works on the other printer, then this printer is defective. Service your printer. If another printer is not available to test with, carefully inspect the power cord for damage. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer. Again, if these steps do not work for you and the issue is still present, then the printer will need a specific part - and I can tell you how to order, install, etc, so that you can do the repairs yourself! =) Just email me at bosscomputers@comcast.net Please rate my help for you too, so that I can track your progress as well as helps me get a better rating =) I really appreciate that, as well as hopefully being able to get your issue resolved/fixed!! ~Darrin~
Jun 10, 2007 | HP DeskJet 890c InkJet Printer
HP Deskjet F2480 All-in-One Printer Logo
Seeker5211
Seeker5211
