Question about Refrigerators
Refrig door does not seal
Fresh Food door does not seal on bottom handle side. Gap between closed door and refrig is 5/16 inch greater at bottom than at top on handle side (1+5/16 on bottom vs 1 on top). On hinge side gap is 1/4 inch greater at bottom than at top (1 on bottom vs 3/4 on top). I have leveled refrig side to side and front is 1/2 inch higher than back. Refrig is just a couple years old and gasket appears to be in good shape.
  • 221 Answers
First off, make sure nothing is stopping the door from closing completely. If the door is closing properly, then using a hair dryer, heat the gasket until soft and pliable. You can carefully stretch it towards the cabinet. There is a magnet in the gasket all the way around on the mating portion. While the gasket is soft, the magnet will pull the gasket until contact is made with the cabinet. Once a good seal has been accomplished, allow to door to remain closed for 30 minutes. The seal will cool down, and the new shape will be maintained. After that, close the door on a dollar bill. Gently tug the portion of the bill on the outside of the door from one corner to the other. There should be some resistance to your pulling. If the bill feels loose, apply more heat to the gasket in that area to improve the seal. DO NOT HOLD THE HAIR DRYER IN ONE PLACE TOO LONG AS IT WILL DAMAGE THE GASKET, AS WELL AS THE PLASTIC LINER.
Posted on May 08, 2014
  • 56 Answers
SOURCE: Refrig door gasket does not prevent gap when door is closed
Lift up the gasket and look for screws securing the gasket to the door.
Loosen all of these screws a few turns and twist the door in the direction needed to seal.
Hold the door in this position as you tighten the screws.
This can be tricky and sometimes requires multiple efforts.
Posted on Apr 03, 2009
  • 864 Answers
SOURCE: door gasket gap
Apply a small strip of soft foam weatherstripping tape to the frame in the area of the gap.  You may have to taper the ends slightly to match the gasket profile or the foam tape will force the gasket open for a greater length.
Posted on May 30, 2009
  • 212 Answers
SOURCE: Refrigerator door not closing
look at bottom of door. there is a metal bracket called your door stopper. this only allows door to open so far. if pushed open to far then you bent this bracket. bent back to normal position. your door will close
Posted on Jun 21, 2009
  • 113 Answers
SOURCE: Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Posted on Sep 15, 2009
  • 41 Answers
SOURCE: i think the hinge has sprung on the frig door. it
check the door hinge brackets there are plastic bushing they may be damaged causing the door to have slack in it open the door and take the handle and pull it towards you there should be no slack if there is it could be a bushing or just a loose hinge
Posted on Nov 20, 2009
Testimonial: "no slack. thanks for that feedback. i'll proceed with the gasket seal. was this in response to magic chef model? i mistakenly put whirlpool to start."
How many cu ft is it? need new seal for door hmg241770 admiral refrig
Not sure what the cubic feet for the doors for that refrig. but i have the part#'s for you
Fresh food gasket 61004010
Freezer door gasket 61004011
hope this is your looking for
Gene
Aug 01, 2011 | Kitchen Ranges
I have a magic chef refrig mod#RB21KW4AF. The fridge door is leaking cold air from the handle side of the door. I changed the door gasket, but it didn't help. The door doesn't have the same suction seal as...
rerack the door ( loosen screws and adjust door / also ck door hing cams if bad replace / this lifts the door and aids in the close .. mm
Nov 22, 2009 | Cooktops
Freezer drawer jars open at upper right corner when refrig door is closed. Air leaks in and is forming frost on frozen food.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Nov 05, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Refrig door does not seal shut.
jack up the two front leveling feet a bit to make it lean towards the back. or put a level on it to see how far it is off.
Dec 04, 2017 | KitchenAid Superba Architect KSCS25IN Side...
Apr 03, 2009 | Haier HSL06WNAWW Compact Refrigerator
No matter what i set the frig to it goes to 24 degrees and freezes everything.
Its funny you posted this problem as I have just finished working on a built in ge with the exact same problem!
any way whats happening is the dampers that control the quick chill area of your refrig arent opening and closing properly causing subfreezing temps in the fresh food comparment. the parts need to repair your unit are the air handler WR31X10023 and seal WR60X10116 these parts are abot 300.00 dollars. I would recomend calling a good service company to repair this for you but if your mechanicly inclined you could do it yourself. the airhandler is the component behind the crisper drawers in the fresh food section of your refrig.
Hope this helps and please post back if you have any questions thanks Peyton
Mar 05, 2009 | GE Monogram ZISS360NRSS 36" Built-In...
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Things freese-up in the kenmore fridge
Try turning down the unit a half knotch, 1 full knotch at MAX, the cold air comes from the freezer to the refrig(fresh food) section, its rolls up the back of the wall to circulate it
A fridge that is to cold is usually shown when food nearest the back wall freezes( i get this call plenty times a day, this is the fix)
recommened freezer temp 0-5, fresh food(refrig) temp is 32-40
May 02, 2008 | Amana AFD2535DES French Door Refrigerator
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
