Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
MY 3 GARAGE DOOR REMOTES WONT OPEN OR CLOSE MY GARAGE DOOR THE ONLY WAY IT WILL WORK IS BY THE BUTTONS ON THE WALL IN THE GARAGE.
    President:
  • 3,197 Answers
If you have the 3 button wall control make sure the lock function is not on. You can tell this if the light in the control is blinking. If it is press and hold the button with the lock icon for 3 seconds. If this is not the case you likely have a logic board problem.
Posted on Jun 22, 2009
My liftmaster formula1 opens everytime but only the wall button will close it. Once in a while a remote will work but rarely. I have one remote, one vehicle oem remote and a wall mounted remote outsid
does it attempt to close. stop go back up and the lights flash....if so check the safety eyes, check for boken spring/ springs using the wall mount button circumvents the safety system. check the down pressure setting.
Nov 15, 2014 | Building Materials
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
Button in the garage works, but remote will not open or close garage door?
That button on the wall is called a wall control. If you have a wall control with 3 buttons and the light in the control is flashing you need to press the lock button and hold for 3 seconds. Make sure the battery in your remote is good.
Mar 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont close with remote control or home link in car. Will only close if continuously hold wall mount button during entire door travel
thanks w/d for getting right on my problem,my closer doesnt have lights at the bottom, it's a garage sale deal. works good otherwise exept I have to hold closer button on the wall to close.
Dec 14, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door will not open close with remote
Press and hold for 3 seconds the button on the wall control with the lock icon.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener remte built in in my van suddenly stopped
TRY DISCONNECTING THE WIRE TO THE WALL BUTTON. IF THE VISOR REMOTE NOW WORKS YOU HAVE A BAD BUTTON.
HOPE THIS HELPS
Jul 30, 2009 | liftmaster Chamberlain Garage Door Opener...
Garage door opening/closing problem
Could be a bad wall button or a smashed wire.
Anytime a door opens and/or closes by itself, or remotes work intermitantly I look for a smashed wire between the motor unit and the wall button or a bad wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
116 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
