Question about Exercise & Fitness
My tredex 6.0 by sportcraft treadmill has e1 error code and e2
SOURCE: Sportcraft TX 2.5 treadmill - error code 3 - stops
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Posted on Dec 20, 2009
SOURCE: my Lifespan treadmill is showing an E1 error code.
my lifespan treadmill has an error code e1
Posted on Mar 21, 2010
maxtreadmill
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
  • 33 Answers
SOURCE: I have a BH treadmill that has an E1 Error messgae...
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 33 Answers
SOURCE: my treadmill is showing an E1 error code, what
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it child's play: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Not working at all. What does error e1 indicate?
HI There,
We would need to know the make and model of the treadmill as they are vastly different electronics wise. The error E1 can indicate a mismatched speed error, no belt movement when it is expected, or a faulty lower control board may also cause this. Older Matrix Fitness machines used "E" for elevation errors and "S" for speed errors but most have changed that format to E1, E2, etc..
Good Luck!
Apr 25, 2016 | Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Getting E2 error on my vision fitness t9250 treadmill
68a1477a-4453-48c8-9f94-cd15c6c6fea7.giffollow this steps and fix it. God bless you
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
See the diagram attached.
Oct 13, 2013 | Exercise & Fitness
Fitline error code E2
his is probably a faulty speed sensor or the speed sensor is not plugged in properly tight it +clean it and test for open or faulty. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1 or e2.. See the diagram attached.God bless you6128a263-dcf3-4c09-8c79-31b0b7b5330a.gif7b2ec1e0-1b92-4934-bfc7-913f3b63ab69.gif
Apr 08, 2013 | Exercise & Fitness
E2 error code on my Tempo 612T treadmill
adjust and clean the speed sensor, and tight the connector very well, see the diagram
2) test the input voltage motor, if there are voltage the motor replace
3) test the output voltage board, if there are NOT voltage , the board is faulty, replace.
God bless you
Nov 11, 2012 | Exercise & Fitness
My Exerpeutic TF1000 treadmill shows a E2 error, motor will not start.
see this steps and fix it.God bless you
This is probably a 1( faulty speed sensor, adjust it , clean it and tigh the plug very well see the diagram attached. 2( test the input voltage motor, if there are the motor need repair 3( test the output voltage board, for input voltage motor, if there are NOT the board is faulty see the block diagram . The error codes will differ between makes and models but could be e1. or e2
Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Oct 01, 2012 | Ironman Exerpeutic TF1000 Walk to Fitness...
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Error 2 in Goldstar MTD 602 treadmill
1) Adjust the speed sensor 2) Tight very well the connection from speed sensor. 3) Faulty Sensor speed 4) Faulty Main Motor measure for 115 VAC without load. 5) Main motor board faulty , test for 115 VAC,and oupput for +5Vdc. 6) See the transformer for 115 VAC,for primary voltage and secondary voltage. 7) See if some component such: resistors, capacitor, diode, or IC burn. 8) Lubricate the deck belt. 9) Adjust the tension for deck belt for lift 2-3" max. 10)error code e1 vs e2 in some mark is equal is different from some manufacturer.
See the block diagram for your diagnostic, for strong resultant.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua.
Dec 18, 2011 | Exercise & Fitness
E2 error after rubbing for 7 seconds
Your problem might be that a magnet has fallen off its holder. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jan 04, 2010 | Bh Fitness T8 Basic Treadmill
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
