How to attach
Iwant to know what leads go where to connect my synergy mixer to my pc
    Top Expert:
  • Computers & ... Master
  • 22,133 Answers
Synergy what?
Posted on May 08, 2014
I want to record using Tascam with my peavey xr1220 mixer
What Tascam recorder are you using? If you are multitracking you will be unlikely to be able to use this mixer. Otherwise get a phono lead to fit the tape out and suitable connections for the Tascam recorder at the other end. This will allow you to record the main mix but unless you are a solo act or putting everything through the PA this will probably be pretty useless to you.
Jan 07, 2015 | Peavey XR 1220 Powered Mixer Mixer Powered
Phonic mm1002
You need a 3.5mm stereo jack to twin 1/4" jack plugs. That will get audio from your laptop to the mixer. Then, being Peavey, probably a pair or jack to jack 1/4" screened leads for signal from mixer to amp. Then loudspeaker leads to suit your amp and speakers.
Jan 02, 2014 | Computers & Internet
Has power on but doesn't run
If you took your brushes out to check them then your mixer will not work if you put the brushes back in the wrong way even if you fixed the original problem. the beveled side of the brushes must go back into the brush holders a very specific way/direction because the brush holders have a pinched corner on one edge that allows the brush to slide past and to make contact with the armature. if you are sure that the brushes are in the correct way lets proceed. (If not get a flashlight and look inside the brush holder for the pinched down corner and reinsert the brushes the right way)
fist the basics, I know it seems dumb to even think this but ... well you know.
1. check the outlet you are using for the mixer to see that it has power.
2. The outlet is hot, look at the rar top of the mixer you will see a small "Phillips Head" screw. take it out. and lift up and out at the same time to remove the the rear motor head cover.
3. take a moment and look at what you see. now look at the cord that you use to plug the mixer into the outlet. follow it back into the mixer head and you will see three wires. Green = ground and it is attached to the mixer frame with a #3 Phillips screw, leave it alone. the other two wires, one black and one white attach to what is called the speed control board by means of two flag style connectors. Are they attached? Or have they or either one of them come off?
4. if they are attached to the flag terminals, then get a multi meter and check for power between the terminals. the black test probe goes to the black lead on the mixer terminal, your red test lead goes on the white flag terminal attached to the mixer. personally i would disconnect these two leads before I tested them to avoid any safety issues with the mixer. If ther is no power to the terminals when you p,lug the cord into the wall then the cord is bad. Order one and replace it. you could also test the cord another way by checking for ohms resistance and you won't have to plug the cord in at all. Ohms testing is safer.
5, if the cord is good then the next thing to look at is the phase control board. that is a small computer style board above and behind the big black and copper board with 3 screws in it. It has 4 wires coming out of it. You probably have no real way to test this unless you are familiar with electrical :Bread Board" circuitry. i usually just carry a new one with me and replace it. It's faster.
6. If the system still does not start I remove speed control plate/board,The black and copper one. (there is a spring attached that will have to be removed, if you let it snap back into the machine you will have to dismantle the entire motor head to dig it out, so hook a cloth under it's clip that will hold it and keep it from snapping back into the mixer). Now install a new spped plate and test again. if you still have no power there are only two electric problems left one is the armature and the stator which are the two components that make up the motor, but it will require a complete tear down to replace. I have never had a motor go out. the problem is usually the cord or brushes. Let me know if this helped. If not we can post a location to the service manual and parts list for your mixer.
Sep 13, 2012 | KitchenAid Kitchen Aid W10240708 Cylinder...
Before my pc have a sound but now it doesen't work. so iwant back the sound of my vedio and the sound also when i play music to my pc.pls give me audio divice that can help me to hear when i watch or...
is any audio device pluged in such as speakers or headphones? are the speakers plugged in? is the volume on the PC turned up, is your device connected securely to your PC?
May 05, 2011 | HP Computers & Internet
I have a Behringer xenyx 802 audio mixer and have lost the power supply. I tried to buy a replacement, but cannot find any in stock. I'm very resourceful and thought I'd make one. The spec sheet calls for...
No, you can't just jump the pins together. The power supply in the mixer needs two separate 18-volt AC inputs because it makes two supply voltages, +15 and -15 volts.
The external supply is just a potted 36-volt transformer with a center-tapped secondary. I bought an open-box Behringer (not your model, but similar) that was missing its supply, and found this transformer which works fine. (I actually did find a couple of sources for a replacement Behringer supply, but it cost more than I paid for the mixer!) Just connect the three output leads to the appropriate places on the mixer's PC board. In mine, I removed the original input connector and soldered a pigtail with a 3-pin connector from Radio Shack to the PC lands, then attached the matching plug to the transformer leads. You'll also need to provide an enclosure of some kind to prevent contact with the line voltage input to the transformer and to protect the thing if you carry it around.
Mar 29, 2011 | Audio Players & Recorders
How do i connect my laptop to my berringer mixer to record and play back through my mixer speakers
You'll have to use the headphones socket, so you'll nead a lead with a stereo micro (3.5mm) Jack for the Laptop end and probably RCA Phono's (L & R) at the other. You'll have to check your Mixer inputs.
Its a fairly standard lead, you should be able to get it at most electrical retailers.
Nov 09, 2010 | Computers & Internet
Hi i have djx 750 and i have connect the master output on my amplifire and the tape or both to my line in from my pc sound card!!! the problem is that when i have open the mic from my mixer i can here it...
i have djx750 mixer, and i want to connect speakers to it,but the cable for the speakers are guitar jack leads and back of mixer are scart can i get a cable with guitar jack and scart on same lead??cheers
Dec 14, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Pc > mixer > amp ......connections.....
Hi Dave ok,you go out of comp(this can be headphone OR audio out on your laptop),into mixer (audio inputs,)then go out of mixer (audio out) into input channel on your amp ,the speakers are obviously already wired up to your amp?
ROd
Apr 28, 2009 | Audio Players & Recorders
Driver
Pls search from www.acer.com website.
Thanks
Mar 05, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
