Why is my washer leaking on the side? - Washing Machines
  • 957 Answers
Most likely that is where the drain discharge is. look in to washer from the back and see if it is leaking by the pump where the hoses hook up
Posted on May 08, 2014
Why does my frigidaire washer leak
Hello friend, I appreciate your post!
I see you are asking about a Frigidaire washer leaking but your question is labeled under refrigerators. If your washer is leaking it could be a problem within your motor, water valve, drain pump, or seal inside your washer. If you are speaking about a refrigerator it could be an issue within your water valve, water filter, or an air leak causing condensation.
I would recommend having a professional come out to the home for a proper diagnose and repair. I hope this is helpful. -Matt
Aug 17, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Washer is leaking water from the bottom right side
check your hot cold connections going into the washer might have to take top part off to seee inside might just be a rubber seal
Mar 17, 2013 | Maytag Washing Machines
Why washer leak fragdiar
There are a lot of reasons that it can leak, Can you tell us where the leak is? The location is critical. Is it under the machine in the middle, right side front side etc?
Sep 09, 2012 | Frigidaire Washing Machines
Water leaking from bottom of washer between the washer and petestal
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps... Please post back if you need more information.
Daniel
Dec 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
Karcher electric power washer is leaking out of the bottom
where is the leak coming from inside? inlet side of high pressure side
Jun 08, 2009 | Karcher PSI Electric Pressure Washer
Leaking water from underneath towards the right side.
The pad is an insulation pad to keep heat in the washer. It might be worth pulling the washer out and checking the water feed and drain connections - it's a good bet one of these is leaking.
Mar 14, 2009 | KitchenAid KAWS700L Top Load Washer
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer top
The following link should give you the steps necessary to remove the exterior washer casing to inspect the interior:
http://www.fixya.com/support/r397092-replacing_water_pump
The instructions are for replacing the washer pump, but the steps to gain access to the interior are the same. If the leak is coming from the FRONT of the washer, check the pump and drain hoses for loose connections. If the pump is leaking, it is not repairable (sealed unit) and must be replaced. If the leak is coming from UNDER THE WASH TUB, this is a symptm of a leaking tub seal, or cracked tub. This requires removal of the wash basket to replace either part. If the leak is coming from the SIDE of the wash tub after it starts to fill, check the air dome hose to ensure it is still attached and not leaking. This is a small air hose that connects to the side of the wash tub and runs to your pressure switch. It sometimes becomes loose or disconnected and leaks. If the leak is coming from the BACK of the washer, check the fill hoses and water inlet valve hoses. I hope you find this information helpful. If you need further assistance, please let me know.
Oct 19, 2008 | Kenmore 15864/15862 Top Load Washer
Asko Washer leak
Remove the bacpanel, and locate the leak. Be careful for moving parts, and electricity.
It may leak from the pump or from a hose or so.
Jan 15, 2008 | Asko W6441 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
