Question about Earthquake 6015V Rear Tine Rototiller
My Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle just makes a squeeling noise and tines won't rotate.
Earthquake Rear Tine Gas Rototiller - 196cc Viper Engine 4-cycle. Just makes a squeeling noise when it starts tilling dirt.
    New Friend:
  • 14 Answers
Sounds like the belt is slipping. Have you removed the belt cover and inspected the belt and the tensioner pulley ? If your model is like mine the tension can be adjusted just below the handles by looseneing the nut where the cable goes into the cable sheath and moving the cable cover further away from the handle. That takes up some slack and will make the tensioner pulley tighter on the belt. If the belt is shot tension isn't going to help.
Try "google" with "earthquake 5070 manual" first option should be a PDF copy of a model 5070 manual. Will have diagrams on how to adjust the cables.
Posted on May 30, 2014
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
Briggs and stratton quantam 6.5 hp fires but will not run
Check for a clogged air filter.Try starting it without the air filter installed. Check for loose wires to the spark plug and ground. I am assuming there is gas in the tank, but does it get to the carb? Check the gas line, is it blocked? Is the carb leaking?
Oct 08, 2014 | Earthquake Rear Tine Rototiller SRT with...
My carburator is getting gas but doesn't flow to bowl. Not starting, not getting gas
Go here and download the Instruction Manual for the tiller:
http://www.getearthquake.com/foundations/DownloadCenter/downloadpopup.asp?file=OM31320E.pdf
Looking closely at the carb, I see it is a very basic bowl and float type.
1) Turn off the gas vavle, so gas won't start leaking all over everything.
Simply remove the nut at the bottom of the carb, and remove the bowl by turning it ever so slightly as you pull down gently on it. Clean the crud out of the bowl, and then remove the pin (it just pushes through) that the float hangs from, and remove the little needle valve and wire holder that keeps it in place.
(study it very, very closely before you do this so you can reassemble everything back properly!)
Jam the end of the spray tube of a can of carb cleaner up into the seat of the valve and back-flush it. You may have to open the gas-supply valve to do this.
When the gas starts flowing, you've successfully cleaned the clog.
Turn off the gas-valve again, reassemble everything, do not over-tighten the nut on the bottom of the bowl, turn the gas back on, check for leaks, start the tiller and you should run just fine!
Aug 27, 2014 | Earthquake Rear Tine Rototiller with 196cc...
Earthquake rototiller won't disengage
the tensioner is to tight and belt stays engaged loosen the tension below the handle
Apr 04, 2014 | Earthquake 6015V Rear Tine Rototiller
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
I have a new Rear Tine Earthquake 6065 electric start 196cc rotor tiller. It runs 5 mins. then stalls and dont start. The first time i thought i was short on clean feul so i filled it. it ran about same...
see if it keeps running with the fuel cap a little bit loose. if so the vent hole in the cap is plugged up and not venting. this causes vacuum in the fuel system and starves the engine of fuel. good luck
May 25, 2017 | Ardisam 5.5 Hp Rear Tine Rototiller
Need a user manual for Earthquake 3365PS tiller
I need a service manual for the earthquake 9800 auger with the 3.8 hp tecumseh.
May 12, 2010 | Ardisam 5.5 Hp Rear Tine Rototiller
I need a forwward cable for an earthquake reartine rototiller #5020dm how to order. thanks
I googled Earthquake 5020DM tiller and show a site that has a technical manual. It has the diagrams and parts numbers. It looks like the forward and reverse cable are the same. You may have to call ARDISAM direct to get the cable.
Oct 02, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Earthquake 6015V Rear Tine Rototiller Logo
403 people viewed this question
Top Earthquake Garden Experts
Mike Forrest
Mike Forrest
Level 1 Expert
cwradio73
Are you an Earthquake Garden Expert? Answer questions, earn points and help others
