Question about Victor Kalart;Model 70;15 16mm Sound Projector
Can't find a pull-down claw for my Kalart-Victor 90-25 projector
Have a Kalart-Victor 90-25 and can't find a pull-down claw for it.
I need a claw arm for a EUMIG MARK 822 projector.
Sorry we have no parts for sale here.
Jun 27, 2017 | Cars & Trucks
Hi,I have a 158cc briggs and Stratton victor mow model 10T602.Can I change the shaft seal from underneath the mower?.Or do I need to pull the motor apart. Thanks.
Drain the oil, tip it over and remove the blade and adapter and key stock if it is not part of the adapter. I drill a few small holes in the old seal and install some wood screws in them, using a claw hammer or flat bar I pry the old seal out. , make sure all is clean. I use a short section of PVC drain pipe to slide over the crankshaft to drive the new seal into place.
Dec 09, 2016 | Garden
Manual for a Kalart Speed Graphic
The best source of info for all Speed Graphic models and accessories, including the Kalart rangefinder, would be Graflex.org.
Jan 10, 2013 | Graflex Anniversary Speed Graphic 4x5...
Cant open Kalart 4x5 Camera
Kalart is the brand of the rangefinder not the camera. A speed graphic normally opens by pressing a concealed button located on the top of the camera middle front. Suggest you also check out the website Graflex.org for further info and shooting tips.
Need to clean filter dont know how and the bulb is running hot.
look under the projector lens and you will see a cover that can be hinged out when the plastic claw lever is pressed in. lift the filter out by the knob
Sep 13, 2011 | Hitachi CP-X443 Multimedia Projector
Eumig 822 sonomatic 8mm dual guage cine projector. Claw fails to engage sprockets in gate. Problem probably due to forgetting about retracting claw when changing formats. Who could service/repair this...
I have a Eumig 824 Sonomatic that needs repair to the claw mechanism, new rotary switch control knob and front sprocket for Super8 mm. Can this repair be effected by you.
Dec 27, 2009 | Cameras
How to replace the wiper insert at the back of
  1. REMOVE RR WIPER BLADE
    1. Raise the rear wiper blade to the position as shown in the illustration where the meshing of the claw disengages with a clicking sound. NOTE: Be careful not to break the claw.
    2. Pull straight the rear wiper blade to vehicle's left from the wiper arm. NOTE: Do not fold the rear wiper arm with the rear wiper blade removed from it.1722d05.gif
  1. REMOVE REAR WIPER RUBBER
    1. Place the rear wiper with the rear end of the rubber protruded from the blade stopper as shown in the illustration. NOTE: Do not pull out the wiper rubber forcibly, as the backing plates will become deformed or the blade claws will become damaged. HINT: The rubber can be easily pulled out by pushing the middle area of the blade.
  1. INSTALL REAR WIPER RUBBER
    1. Install the 2 wiper rubber backing plates to the rear wiper rubber. NOTE: Be careful to observe and keep direction of curvature for correct replacement.
b. Insert the rear wiper rubber from the claw of the middle of the rear wiper blade into the rear end position.
c. After passing the rear wiper rubber through the rear end side claw, protrude it from the rear end stopper and pass it through the front tip side claw.
Sep 12, 2009 | 2005 Toyota Matrix
How do you raise the shoulder straps up to a higher level on the Britax Marathon carseat?
The straps must be undone from a claw on the underside of the car seat so you have to remove the whole thing from the car. The claw is designed to keep the straps in place and this it does very well but its position on the undercarraige leaves no room for your hands and makes it near impossible to manage.
Jun 13, 2009 | Britax Marathon
Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Dec 19, 2008 | Toshiba TDP-S8 Multimedia Projector
I am in the sky city and cannot get to the tower where the boss is .
You need to claw shot up to the pillar that has vines growing up to where the top is broken off. You can climb up to the top, stand up, and then reach the ball with your claw shot. Use the steel boots to weigh it down and presto!
Nov 04, 2008 | Nintendo The Legend of Zelda: The Twilight...
Victor Kalart;Model 70;15 16mm Sound Projector Logo
49 people viewed this question
Top Victor Office Equipment & Supplies Experts
k24674
David Burbee
David Burbee
Andrew Taylor
Andrew Taylor
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
