Question about Breville BTA820XL 2-Slice Toaster
Bta820 carriages stay down in toasting position while elements are off?
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Nothing works except toast position.
Probably a burnt out element. See this video if you want to fix it
Jan 05, 2016 | Kitchen Appliances - Others
Why won't my calphalon toaster oven toast top of bread? Why?
If both the top and bottom elements are working then you may need to re-position the rack closer to the top element for even toasting. If there is only one rack position available then you may need to flip the bread and toast it twice.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Oct 06, 2014 | Toaster Ovens
Lost measuring cup
follow this test and fix it. God bless you
If the toaster doesn't work at all, make sure power is on at the electrical receptacle and test the power cord.
If the carriage lowers but doesn't latch or latches stiffly, look inside for food debris that may be blocking the carriage. If the latch is damaged or obstructed, service the assembly (see below).
If the bread toasts only on one side, check the heating elements for damage and replace as needed; or replace the toaster.
If the carriage doesn't pop up and the toast burns, check the thermostat calibration and correct any inaccurate calibration (see below).
If the thermostat is faulty, replace the thermostat or the toaster. Check the solenoid switch and solenoid; if faulty, service (see below) or replace.
If the toast is too light or too dark, check thermostat calibration and correct if necessary (see below)
Nov 14, 2013 | Back to Basics Kitchen Appliances - Others
Toaster won't stay in down position in order to toast - Cuisinart CPT-160 - although it will toast if I hold the lever down as it toasts
We opened up our toaster and scraped some baked-on crumbs off the top of the electromagnet that controls the carriage catch. When we closed it back up, it worked again.
Dec 22, 2009 | Cuisinart CPT-160 Metal Classic 2-Slice...
Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Aug 04, 2009 | Kitchen Appliances - Others
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
Bread will not stay down
Be sure the temp/time dial is not on zero.
Mar 11, 2009 | Russell Hobbs 9376 Classic 2-Slice Toaster
Tefal toaster wont stay down - Avanti Elite, twin.
Hi, I assume that you had the toast carriage pushed down when you check the solenoid (hold down coil) volts ? .. a bit dangerous to try though
Either way, try resoldering the solenoid connections, they can develop hairline cracks that limit the current.
Feb 11, 2008 | Kitchen Appliances - Others
Breville BTA820XL 2-Slice Toaster Logo
90 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
