Question about HANNA instruments Hanna Dist 1 TDS Pen HI 98300 eco-5524
Ppm 98300 hanna instrument manual - HANNA instruments Hanna Dist 1 TDS Pen HI 98300 eco-5524
Hanna hanna clue famous people starts with r
Hello i dont know any hanna hannas but if your playing clue pics on level 19 the answer is Rihanna :)
Aug 12, 2013 | Office Equipment & Supplies
How do you change the battery?
take the positive and negative off the old battery put in new battery replace cables
Jan 12, 2011 | Hanna Instruments Waterproof pH Tester...
I balance it to 7 with solution. Then check my water and it says its 7.22 but when i check with the good ol drops its about 6.5 or 6.6 and sometime it is even way off more. and have to adjust it everytime...
Is this a automatic pH meter?
The only reliable way to measure your pH is by using a test kit. The automatic devices must be adjusted and set at least as often as the manufacturer recommends.
Your pH should be between 7.2 and 7.6. Your Alk should be at 100 (between 80 and 120) Get the Alk right before you try to get the pH at 7.2 or 7.4. These changes you are making should be measured over a number of days not a number of minutes, by the way. Alk 'buffers' pH and prevents pH 'bounce'.
Does your filter system run 24/7? Point of interest, most commercial pools should have a 8 hour turn over rate and run 24 hours a day for best results. Spa's should turn over on a 2 hour basis.
I don't know where you are writing from, the acceptible pH in the USA, generally, is 7.0 to 7.8. 7.0, while not really bad, is more acid than most swimmers can enjoy.
Other considerations: Your calcium should be around 250/300 ppm. Outside pool? Cyanuric Acid should be around 70 - 80 ppm. CL should be around 4 ppm. If you are using Bromine, the Br number is 2 X the CL number. By the way, Bromine is about 2 X more expensive than CL. Might you be using salt and making your CL? Salt should be 3200 to 3400 ppm and you should monitor your CL and adjust daily to get your 2 to 4 PPM cl. You MUST protect this CL with Cyanuric Acid.
I hope you find this information helpful. The courtesy of a positive vote will be appreciated.
Thank you for your interest n FixYa.com
Aug 28, 2010 | Hanna pHep pH Meter with Solutions
Puk code for samsung e1410 .i mistakenly entered pin code for my fone thrice and am unable to find my puk code anywhere 1i have vodafone connection.(state kolkata,India)Help PLZ
PUK refers to Personal Unblocking Key. This is a Code which is offered only by Service Provider. There is NO charge. Call up Vodafone and ask for the same and they would be glad to offer that.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 19, 2009 | Samsung Cell Phones
The probe won't measure the temperature, but it measures conductivity, pH and TDS accurately. 0.0 °C keeps flashing on the screen.
Is this probe in Robinair AC machine ? if so,the you neet to replase new one.because it seems to be broken ( probe tip sensor)
Jun 26, 2009 | Hanna Instruments Waterproof pH Tester...
HANNA instruments Hanna Dist 1 TDS Pen HI 98300 eco-5524 Logo
73 people viewed this question
Top HANNA instruments Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a HANNA instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
