Question about Vehicle Parts & Accessories
Can you tell me why my blinkers flash left to right, without sound, for a few minutes after I start my rodeo? It also can happen if I open and close a door.
    Problem Solver:
  • 6 Answers
Change your flasher unit relay sometimes located under dash or under front bonet.
Posted on May 14, 2014
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
New battery installed in 2002 mercury cougar, and the alarm goes off and the left and right blinkers flash.
It sounds like you have an aftermarket alarm system that has malfunction. Contact the manufacturer of the alarm for the reset procedure.
Apr 21, 2012 | 2002 Mercury Cougar
I have a 2000 Dodge Durango and we have been having blinker problems too lately. Sometimes they worked, sometimes they didnt, and the other day they went out completely.They have been doing this for a...
that vehicle has a desperate relay for the hazards which is why they work, you have a defective signal flasher sometimes called a signal relay, follow the noise to locate exactly where the part is, usually under driver side of dash, it is a very cheap part and easy to install.
Sep 26, 2011 | 2000 Dodge Durango
Break light flashes when i turn blinker on xr650l put on new blinkers not sure wiring is correct
It sure sounds like you have a few wires crossed. Start from fresh. Make sure that your light fitting's earth wires are all connected correctly. Put on the right flasher and connect wires till you get the right flasher working. Do the same with the left flasher and the last wire should be the brake light wire, test it to make sure.
Feb 19, 2011 | 2005 Honda XR 650 L
Right blinker works, but left one doesn't work at
either check for voltage at the blinker and also check for left blinker fuse . NO voltage at connector there is an open in wire replace try to find the open torn insulator or wire being exposed.
Jul 02, 2010 | 1997 Mitsubishi Eclipse
Blinkers don't work: When I use my blinkers to
The right blinker issue sounds like you have one bulb out either front or rear check them both. The left blinker issue sounds like either bulbs(both out) or fuse, or worst case blinker switch has gone bad on left turn only so not picking up the signal.
Mar 18, 2010 | BMW 525 Cars & Trucks
Have a Chevy Corsica 1996. Blinkers not working right. When I step on brake the arrow on instrument panel for the right blinker lights up. When use left blinker, both flash like the flashers are on. ...
It sounds like a bad light socket. The brake light and the parking/running/regular part of the socket are shorting out. When you press on the brake petal it's shorting out on the turn signal and sending current to the indicator (arrow) on the dash.. When you use the blinker, it's shorting with the brake light and causing them both to flash...
Check the socket and get back to me with the result.
Mar 14, 2010 | Chevrolet Corsica Cars & Trucks
Blinker works intermittently
more than likely u have a bad flasher. to use it in the meantime, do this: push the lever just enuff to see the arrow flashing (before it starts buzzing), then hesitate briefly and slowly move the lever into the full position. or if u prefer u can hold the lever at the flash until your turn is made.
Jul 29, 2009 | 2002 Daewoo Lanos
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
