Question about Plumbing
I have a aquasource faucet and the top button is
I have a aquasource faucet and the top button is stuck
  • 21 Answers
Unfortunately, Aquasource is an imported faucet by Lowe's, and parts are not easy to get. You might want to visit a Lowe's and see if they have a replacement diverter unit for this faucet. If you can get one, it should take about 10 minutes to install, then you'll be like new again.
Posted on May 25, 2014
Aquasource toilet has no water going into tank
The fill valve could be stuck or defective.
May 27, 2017 | Home
I would like to replace my shower handle and skirt. Are Delta parts compatible with Aquasource?
go to your local plumbing supply they will give you handles and trim parts that will fit in different stiles for your brand faucet
Apr 13, 2016 | AquaSource Stainless Steel Replacement...
How do I tighten the hot water handle on a moen 4720 bathroom faucet?
many two handle faucets have either a cover button on top or on the side, top button types generally can be tightened with a screw driver while the side button style typically requires an allen wrench (hex key)
Oct 19, 2014 | Plumbing
Aquasource 2 handle Kitchen Faucet with sprayer as a fourth piece
I recently installed one and the center is the "holddown" hot and cold were just the hose feeds to faucet. There was a ring in center that had two screws up to base from underneath sink (hex key). Remove center ring and wiggle whole unit up and out. Dont forget to turn off water main and drain lines beforehand. Have fun.
Mar 10, 2014 | AquaSource Stainless Steel 1-Handle...
Hansgrohe talis s stuck in spray mode
Some disassembly may be required to determine the cause of the stuck button and fix it. There may be mineral deposits preventing proper operation.
Jan 20, 2014 | Plumbing
Diminished water flow
clean the screen inside faucet
Dec 16, 2013 | AquaSource Plumbing
Replace diverter in 2 handle aqua source kitchen faucet
For a dual-handle Aquasource kitchen faucet with spray hose, the following instructions will afford replacement of the diverter. These instructions specifically refer to the faucet illustrated at http://pdf.lowes.com/installationguides/6953123900358_install.pdf, and the diverter identified as part RP70007 (item 14). Note the position of notches at the top of the diverter and around the rim of the base of the diverter, either of which can be used to leverage a tool to rotate the diverter out of position. Caution: The diverters on older faucets may be exceptionally brittle and thus very difficult to remove.
1. Using a pipe wrench or similar large-mouth wrench, unscrew the base of the faucet. Wrap the base with a cloth or other protective material to prevent scratching during the process of unscrewing. The base unscrews in a counter-clockwise direction.
2. With the base removed, remove the faucet. Note that a small amount of water may drain from the faucet when removed.
3. Removal of the base reveals the top of the diverter, which is a white, plastic cylinder approximately two inches long with copper stopper in the bottom. Insert a wide, flat-blade screwdriver across the notches in the top of the diverter - but be *extremely* careful. A faucet that has been installed for some length of time may have an exceptionally brittle diverter. If the upper shaft of the diverter breaks, a pair of needle-nose pliers may be used in the notches around the *base* of the diverter. Carefully rotate the diverter counter-clockwise to remove it.
4. Insert the new diverter and screw it into place in a clockwise direction. Apply a wide, flat blade across the notches in the top of the diverter to apply slight additional pressure to tighten the diverter just beyond hand-tightness.
5. Re-insert the faucet.
6. Screw the base back into position, tightening as necessary.
7. Test the operation of the diverter by operating the cold and/or hot water faucets, then the spray handle.
Dec 24, 2012 | Plumbing
When shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
Nov 14, 2012 | Plumbing
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Bought an aquasource faucet and it came with no manuel #0310457
go to the lowes website or just go to the lowes and they will give you one.
Dec 03, 2010 | Home
Plumbing Logo
261 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
