Question about Vivitek D825MX DLP Projector
Vivitek Troubleshooting Blinking 20 times
Projector auto shut down
The blink pattern indicates the LED emitter is overheating.
Sep 08, 2014 | Vivitek QUMI Q2 720p LED Projector QUMI-B
Vivitek D326MX DLP, does no power up right away.
Almost certainly a faulty switch mode power supply. Since these are both complicated and dangerous for the inexperienced to play with, the best advice will be to take it to a service centre for repair. It's almost certain to be either failing electrolytic capacitors, or a high value startup resistor, or both, in the smps :o)
Apr 07, 2014 | Vivitek H1080FD DLP Projector
I can't get my Vivitek projector a d952hd model to show light anymore - it is only 6 months old and I doubt it is the bulb as it looks new and the image had not diminished at all in recent weeks - we...
hi,
All projectors have self dioganisng function. If there is any malfuction inside the projector it will indicated by the LED blinking. You have to inspect how many time the LED blinks or which LED lights condinuosly. LED meas the power light or the lamp light. Then only anybody can suggest you a better solution.
ok
Jun 21, 2011 | Vivitek D825MX DLP Projector
Power light flashes 5 times and then ready flashes 3 times
Unfortunately that is 2 different errors... One being easily fixed. The 5 blinking power LED means its time to replace the Lamp, thats the easiest one to fix.
The blinking ready light means a "Fan 3 error". There is no reference on what that could be. It could be as simple as cleaning the air filter, or as complicated as replacing one of the fan units. You will need to contact Vivitek to know for sure:
http://www.vivitekusa.com/v_contact_support.asp
Attached you will find a chart for diagnosing the Power and Blinking Ready Lights:
Mar 10, 2011 | Vivitek D825MS Projector
One year to the date television stopped working ,,, tv would start blinking and could hear but not see
This happened to me also. I just made the deadline to receive a replacement lamp from Vivitek by 2 days, because of the warranty. If not, I would have had to pay $250. This happened in 2009. My replacement went out in Dec, 2010 and I can't find a replacement anywhere. Order a new lamp, hope this works.
Feb 21, 2011 | Vivitek V37655 56" DLP TV
Three green lights and two orange light blinking
One of them "LAMP" LED light indication is blinking?Yes,mean ur tv projection lamp life is over.Tv projection lamp been inside this tv like 1 1/2 or 2 year and tv been on and whatches like 4 or 5 hours of tv daily?Yes,to all these mean ur tv projection lamp require replacing.
Jan 13, 2011 | Vivitek V37655 56" DLP TV
Vivitek D825MX DLP Projector Logo
73 people viewed this question
Top Vivitek Office Equipment & Supplies Experts
Electro Med Services...
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
