Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Raypak boiler BO 538 auto start fail to ignite in the mornings,
Starts manually when button is pressed and works well,stopping and starting during the day,any comments welcome.Thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Raypak Master
  • 1,448 Answers
Do you have this on a timer? if so run without timer if pump goes off and heater is on it will error out if keeps on check gas pressure to heater if too low it will error out
Posted on Jun 10, 2014
2 Suggested Answers
  • 368 Answers
SOURCE: My Raypak 406A was out of propane. Now there is
Sometimes when either a propane or natural gas system has air in the lines they will not work. To be safe I would recommend you call the Raypak technical support line at 800-947-2975 or800-627-2975 and they should be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Posted on Aug 27, 2011
Boiler starts banging and jumping after 20 seconds of burner igniting and then hot water comes from the pop-off valve, what is the problem?
water flow not enough water boiling inside check manual bypass spring could be bad if ok if plumbing bypass only open half way
Feb 13, 2014 | Raypak Pool & Spa
The boiler stopped twice during a week. The reset button was pressed whenever to start the boiler again(twice during a week). Is it abnormal? Does the reset button need to be replaced?
Good Question!-- Let's see if we can figure this out--
What kind of fuel are we talking about? - Gas or Oil?
Any clue as to WHY the boiler stops?--
Can you see a water level, or a temperature or a pressure setting/ gauge?
Tell us what some of these readings are--
If it is gas-- how does ignition take place?-- Spark, or ignitor ignition?
Where is the Reset button?-- is it on the burner control-- or the water level control?
Tell us more--
Mack B
Jan 17, 2011 | Heating & Cooling
I have a raypak 2100, looks like its a 1997 model (seriel# starts with a 97). Unit starts up fine, runs for about 5 minutes and shuts off. It's not close to reaching temp, and I get get it start back up...
If your Raypack (mine is a 2100 but most have the same electronic ignition pilot) lights and runs for about 2-5 minutes an then shuts off, you need to clean the pilot sensor. The pilot sensor tells the unit the Burners are running. If the pilot sensor becomes corroded, carbon, etc. the unit will light but will shut off after a few minutes as it thinks the unit is not operating properly. The unit will try to re light, but fail, and then PLT will show on the main programming screen. To fix the probelm, shut off the unit power. Remove the pilot assembly which is located at the bottom right of the unit. There is one screw holding the pilot assembly in place. Gently remove the pilot assembly. There is a fork like probe sensor (not the one with ignition and gas feed) that needs to be cleaned. Take some rough sand paper and clean it thoroughly. Re insert pilot assembly and fire the unit. If this fails, clean the sensor again. Problem solved!
Sep 19, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Aug 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
Disable Printer Spool Option?
To manually stop and restart the spooler service perform the following steps:
1. Click Start, click Run, type command, and then click OK.
2. Type net stop spooler, and then press the <Enter> key.
3. Type sc config spooler depend= RPCSS start= Auto, then and press
the <Enter> key.
NOTE: The spaces between = and RPCSS and = and Auto are important.
Without these spaces, the command will fail.
4. Type net start spooler, and then press the <Enter> key.
Jun 15, 2009 | Canon LaserCLASS Fax 710 Printer
Timer instructions for a Rangemaster Toledo dual fuel 90 required
OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
Dec 22, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Heater not going on
Please send back the model number. Then we can narrow the roblem down.
Thx,
Peanut
RepairUSA
Jan 07, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
74 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
