Question about Nextbook Tablets & eReaders
Want t order another charger?
Everything works fine just need another charger if possible
  • 776 Answers
They are available on amazon or eBay. And even Sears.com
http://www.amazon.com/s/?ie=UTF8&keywords=nextbook+chargers&tag=googhydr-20&index=electronics&hvadid=36244193798&hvpos=1t1&hvexid=&hvnetw=g&hvrand=15346353562819548438&hvpone=&hvptwo=&hvqmt=b&hvdev=t&ref=pd_sl_6og39ckobd_b
Posted on May 08, 2014
My RCA tablet won't turn on and will not charge, what can I do?
If battery is depleted, then no, it will not turn on.
If battery charger is dead, phone won't charge or turn on.
If battery charger cable is broken, tablet won't charge or turn on.
You need to ensure you have a good working charger, and a good cable. Only a known good charger and a known good cable can charge the unit. Borrow or invest in a new charger and cable (they're cheap on eBay).
Only once you know the charger and cable are good can you determine that they are not the problem.
Depending on how old the unit is, it's possible the battery can no longer hold a charge and needs to be replaced. You won't know that though until you first determine the charger and cable you're using are working properly and providing a good charge.
May 07, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
My Kindle will not charge
Here's a possibility, I just plugged in my Kindle Paperwhite using the Kindle charger and USB cable. It wouldn't charge.
I kept it plugged in all afternoon and it accepted no charge although it showed the little lightning bolt on the icon suggesting it was charging.
I unplugged the charger (it has two prongs) and reversed it so
the logo was on top and, Lo and Behold it charged. It could be the plug is not omniidirectional (i.e. it is polarized)
Feb 14, 2015 | Amazon Kindle Paperwhite
My kindle is not charging
Is the device new or still under warranty? Is return to the store (RMA--"Return Merchandise Authorization"--through an online vendor) still possible? Extended warranty?
Is the charger (and outlet) OK? If you may attempt to use USB current from your PC/Laptop/etc., is that port workable and powered? Have you attempted an alternate method of charging? Is syncing then possible?
Chargers are not invulnerable--rarely, they sometimes overheat and die. After all, they're fabricated PRC items too--thus, even they may prove defective. (They're far less complex than a Kindle or phone, though--defective chargers thus prove quite rare.)
Chargers can't last indefinitely or through overly heavy use, either. (Chargers do tend to last longer than devices--failure proves quite rare!) Is the charger unusually hot after plug-in? (Such failure could prove a great danger to electronic devices. Very rarely, even fire or sparking is possible.) Is charger connection at the wall OK? (Is the outlet overloaded?)
Is it a "block" charger?: These may be replaced easily. Just get the connector and the Volts correct--with sufficient amperage (current). You don't need even to obtain the same brand and model as OEM--that which came originally with your charger. Online, amazon, Radio Shack, etc. may prove very helpful for such purposes.
Does the connector have sufficiently good contact through your Kindle's circuitry to its batteries? (Is the connection overly loose? Often, this occurs over time.)
Are you certain that the charging cable is OK? Does the connector in the Kindle need "doctoring" with a small tool, somehow? If the batteries are dead, it's likely possible to replace them.
It's possible that the device simply is dead (shorted-out)--power surge or fluctuation certainly are possible and likely culprits.
An extremely remote possibility is that the CPU or other key chipset is dead--even those prove useful for limited numbers of cycles. (Failure then implies quite extreme usage! Probably not!) It's not immortal!
Jun 28, 2014 | Amazon Kindle Wireless Reading Device
Trio stealth G2-9 battery life will not charge
It's possible your charger is faulty. If your unit can charge with a USB cord through a computer try that. If it charges then your charger is faulty. The charger can be tested with a voltmeter by someone knowledgeable. The other problem possible is that the charging receptacle is faulty. That would show up if the USB method doesn't work. If the charger is o.k. then your battery won't hold a charge and needs to be replaced.
Mar 20, 2014 | Mach Speed Trio Stealth G2 Tablet -...
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
Sep 04, 2017 | Trio Stealth G2 7 inch Tablet with 8GB...
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
Galaxy Samsung tab 10.1 won't turn on
you had to plug it in the charger for a while and then you hel the power button for more than a minute
if it not work hold power button and volume up for 20 sec.
Mar 22, 2013 | Tablets & eReaders
My galaxy tablet was fine yesterday but today it will not turn on. The battery ran dead and I pugged it in and nothing, The red light does not even come on to show it is charging. I have tried both the car...
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
Mar 13, 2011 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
61 people viewed this question
Top Nextbook Tablets & eReaders Experts
D. E. Hev
Tom
Dustin
Dustin
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
