Question about Sony PlayStation Portable (PSP) Console
Hello...i start my PSP everyting is OK but whe i try to play game slow?
  • 67 Answers
Your memory may be to full to run a game as fast as it is supposed to be try deleteing usless info
Posted on Jun 22, 2009
Psp slow
It may either be your connection or the servers are full on whatever game your playing try it on a different wifi
Dec 03, 2012 | Video Game Consoles & Games
Hello There, :) i've updated my PSP to version
you wont be able to play .iso files(games in the iso folder) because you updated to Sony's official firmware. but in order to play .iso files again you will have to hack you psp and make sure its running cfw(custom firmware).
May 15, 2011 | Sony PSP 2000 Console
My psp works really good but when i try to play games or movies it starts to slow down and flicker
1. Set “UMD Mode” to M33 driver NO UMD
The PSP firmware version was 3.71 M33 but is also tested with higher versions like 3.8 M33. These firmware versions should have the UMD mode to M33 NO UMD.
To set the following you need to go to the Configuration Page. To go there you need to:
i. Turn off your PSP
ii. Press and hold the R button. While doing that slide and hold the power button up. This would turn on your PSP. You should hold until the black screen appears saying “M33 Recovery Menu Configuration”
iii. If the PSP just turns on to the normal menu, just repeat the two steps above.
2. Set “Use VshMenu” to Disabled.
It is also in the configuration page. Use the steps above and you should be able to find it.
Now after these two steps, if you continue no further, your PS would run faster – but only for the menu screen. The menu would be fast and really responsive. However, try playing a game. You would notice that loading is still slow and the gameplay is still played in slow motion
3. Set the CPU speed to Default.
Now this is really important. The CPU may not really be used when playing music or in the menu screen but its very important when you play games.
There are two settings you need to adjust. Speed in XMB and Speed in UMD/ISO. For us normal users we just need to set these two to “Default”.
After this, your PSP should be running ok. However, I recommend that you do another step which would also help the performance of your PSP.
4. Free up memory from your Memory Stick.
You can do this using two methods. One, you could connect your PSP to your PC using a USB cable. Two, you could remove your memory stick and use a card reader. I prefer the second method but you may use any of the two.
Method Two: Remove your memory stick and use a card reader.
Freeing up memory is easy, if you know what files to remove. As my friend is not really using her PSP for music and videos, majority of her files are game files. What she does is that she just puts games that she really plays. I recommend doing the same for your PSP.
Game files are located at the folder named “ISO”. The game files have a .CSO file name extension. You don’t need to delete them. Just transfer them to your hard disk. That way, when you want to play them again, you just have to transfer them back to your memory stick.
But if you have music and video files that take up much space, I recommend that you look into those first. Normally you would like to have at least 500MB of free disk space. You’d need the space for your game saves.
My friends have done the steps above with ease and have solved their slow PSP problems. Most of them, if not all, had to do all four mentioned above. The first three usually solves the problem.
Mar 07, 2010 | Sony PlayStation Portable (PSP) Console
Slow Motion Loading Of All Game On My PSP Console.Don't know why?
just press select button then u'll fine cpu speed make it default.
Jul 25, 2009 | Sony PlayStation Portable (PSP) Console
The disc isn't spinning so the game isn't playing
try different games or playing the game with the PSP in diferent positions, ex upside down, sideways...
and let me know if it works. If it does something is lose inside, if it does not the laser reader or LCD casing must be replaced.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Slim...
Psp menu problem
Ok, your psp CPU clock speed is set to low speed.. 2 way to change:
1. If your psp has VSH menu enable.. : press "select" button, a small window will appear, otherwise its set to "disable".. See at "CPU CLOCK XMB" must set as "default". use left-right d-pad to change it. if vsh menu is disable you can try 2nd way.
2. Boot PSP under Recovery menu ( Hold R-trigger when turn on your psp ).. under M33 menu select "CPU Speed" then press "X", select "Speed in XMB" and "Speed in UMD" to setting as "Default" by pressing "X" button a few times.
Hopefully this help.! Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
http://e-arena.blogspot.com.
Nov 06, 2008 | Sony PlayStation Portable (PSP) Console
Psp
First Tell me about your PSP firmware Version. If its a orginal SONY firmware you can't play the games from the memory stick. If you are in custom firmware follow this procedure.
1.press the SELECT button so you will get the M33 VSH MENU
CPU Clock XMB - Default
CPU Clock GAME - Default
USB Device - Memory Stick
UMD ISO MODE - Sony NP9660
ISO VIDEO MOUNT - NONE
Make sure that its showing as per the above values. if not change it to the above values.
If still the problem continues check these too..
Go to the recovery menu.>>> configuration >>> Game folder homebrew (currently: 3.XX or 4.XX kernel)
if its showing 1.50 change it to 3.xx or 4.xx
also
Go to Recovery >> Advanced >> Advanced Configuration
and make sure that both the options are Disabled.....
Jul 24, 2008 | Sony PlayStation Portable (PSP) Console
Psp lags / delayed action
Are you running with custom firmware like M33 or HX?
If so, you can switch your psp off (not stand by), and hold R trigger when you switch it on, it should bring you to the recovery menu, where you can setup your XMB cpu speed and Game cpu speed, both set to default will be fine.
Dec 24, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
