Question about LG WD-1280FHD Front Load Washer
De error code on lg washer machine - LG WD-1280FHD Front Load Washer
  • 489 Answers
SOURCE: DE error code
That is a door switch error problem.  The door latch is not sensing the door closed.  You may need to replace the door latch assembly.
Posted on Apr 28, 2008
  • 489 Answers
SOURCE: de is displayed when i turn machine on
You may have a door latch problem and it will need to be replaced.
  • 12 Answers
SOURCE: LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Posted on Oct 24, 2009
  • 21 Answers
SOURCE: I am getting a de error code
Drain error
Posted on Jan 02, 2010
  • 3 Answers
SOURCE: my washer want do nothing
Verify suitch door.. drain filters or drain pump... or PWC Board
Posted on Jan 06, 2010
Why does my LG washing machine model WD(M) 16115FD show error code dE?
It appears to be a problem with the door? You can go to the following link and try their troubleshooting, hope it helps. http://www.ehow.com/how_7850983_troubleshoot-de-code-lg-washer.html How to Troubleshoot DE Code for an LG Washer eHow
Aug 10, 2014 | LG WD-16115FD Front Load Washer
What is LG washer code dE?
The dE error code indicates a Door Error. The washer thinks the door is not closed. Have a look at these...
1. There should be a plastic finger on the door that pushes the door switch when the door is closed. Is the plastic finger broken off by chance?
2. The switch itself could be bad.
3. If you overload the washer, this could cause this error code also.
Aug 10, 2014 | LG Washing Machines
What is the error D3
I think that should be a "DE" error code. On LG machines the DE error code is for a "Door Open Error".
Check the condition of the door lock, door hook and switch as this will give the error code above, the switch can be checked with a multimeter for condition. You might need to replace the door hook or the internally mounted switch.
May 25, 2014 | LG WM-2077C Front Load Washer
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
Have a de error so washer won't work how do i fix?
A DE Error Code is indicative of a "Door Error"
Check in this link the LG procedure: lgknowledgebase.com/kb/index
Hope helps.
Aug 11, 2011 | LG WM-2277HW Front Load Washer
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
De is displayed when i turn machine on
Error code DE means door error problem.  Could be that the door switch doesn't sense the locking mechanism is working properly and may need to be replaced.  This will require a service call from a qualified LG tech to diagnose the problem.
Jan 04, 2008 | LG WM1814CW Front Load Washer
Error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
Mar 29, 2007 | LG WD-1280FHD Front Load Washer
LG WD-1280FHD Front Load Washer Logo
15 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
